Capacitor questions please...
  • MarkJnK
    • 26
    Hi guys, just finished my hull prep as per Darin's tutorial, and then topped it off with urethane expanding foam. The hull feels incredible now, no more flex.
    I want to prep the boat for a weekend of hard racing, my family has a family reunion every year and all the men race boats for fun.
    Regarding capacitors:
    1) Will adding a cap board such as the one sold by OSE protect the factory cap? Or is it still the weak link? Should I remove the factory cap if installing the cap board?
    2) If I want to replace the factory cap, how do I remove it? It looks like it is molded in there.
    3) Once removed, do I have to re-seal the ESC for waterproofness?
    4) Lastly, what type of cap is required?
    Thanks all.
  • Drag Boat Bob
    • Apr 2009
    • 304
    Thanks all.
    1. Yes the ETTI cap board will work. Some here use one.
    No need to remove the factory cap if it is still good.
    2. It can be removed with a hack saw or similar.
    3. Yes. You can use liquid electricians tape.
    4. Kintec Racing has the most common cap used for about a dollar each. I used 2.
    • bigpapa
      • Apr 2009
      • 2330
      capicators
      or u can use up to 5 of thease
      avaiable at kintec racing
      • bigpapa
        • Apr 2009
        • 2330
        http://forums.offshoreelectrics.com/...ead.php?t=8917
        • bigpapa
          • Apr 2009
          • 2330
          Modded ul-1 esc
          WITH 3 CAPS
          http://forums.offshoreelectrics.com/...ead.php?t=8835
          • longballlumber
            • 3132
            My Cap install
            For those of you interested, here are pictures of an extra cap installed on my speedo....
            • Capt. Crash
              • Jan 2009
              • 301
              Very good pics...leaves no doubt as to how to do it...thanks!
              • longballlumber
                • 3132
                Thanks Capt,
                I used to have it configured a little differently that is why you see so much exposed wire. However if done to a stock speedo you don't need to remove as much wire insulation.
                Mike
