NEW Nue 1415 motor size
  • detox
    • Jun 2008
    • 2318
    Heres the new Nue 1415 1y 2200kv motor size compaired to the Fiago 9XL 1853kv. 1415 shares the same size rotor with the Nue 1500 series motor. The 1415 Nue comes with flat ground motor end shaft...so no more grinding of shaft to make that collet fit. The Nue comes with larger bearings so fitting of thrust washer will be more difficult than Fiegeo. Nue's case diam. is .031" larger than Fiago XL. More 1415 versions are to come. I paid $179.99 for the Nue. http://www.castlecreations.com/produ...rs/nm1400.html
    1415......... case diam. 1.441" case length 2.775"
    Fiago XL.... case diam. 1.410" case length 2.920"
  • Ub Hauled
    • Aug 2007
    • 3031
    Thanks for the comparison.. it makes a lot more sense now that I see it... I have been looking and thinking abou this motor for a little while now.
    BTW the name of the Chinese motor is "Feigao"
    • Steven Vaccaro
      • 8723
      Why not just get a 1515?
      Steven Vaccaro
      • detox
        • Jun 2008
        • 2318
        The smaller case size takes up less room, price is a little cheaper than 1515, weighs less, allows me to use smaller pinion gear in my 3905 Emaxx, full length flat spot on shaft (no grinding), and 1515 1y versions are currently out of stock at OSE.
        • Heath M
          • Mar 2008
          • 806
          And the 8xl 2073 KV :)
          I've been thinking about using 2 of these in a twin cat setup..
          Heath
          Brisbane,QLD, Aussie
          • detox
            • Jun 2008
            • 2318
            Heath
            Excuse me...that is a Fiegeo 9XL 1853kv motor in picture, but all XL's are same size.
            • Ub Hauled
              • Aug 2007
              • 3031
              this one has the same 540 dia. Steven, one can use it in a car and jets... imagine the possibilities (and crashes)!
              I think "Sneu" is reaching into a new share of the market...
              • Heath M
                • Mar 2008
                • 806
                I see you edited your post
