NEW Spektrum MARINE Receiver
  • Darin Jordan
    • 8335
    I can FINALLY say something...
    Spektrum Radiosjust announced the release of their new MR3000 Marine Receiver.
    Page error. Please use our search bar to find what you’re looking for.
    More details and information can be found here:
    I have been testing these receivers for them since the start of the season this year and have had very good results. I've tested them in my P-Spec OPC Tunnel at ranges out to 980ft (that's as long as the lake I was on... so I couldn't go any further), and still had full control of the model.
    These RXs are VERY light, and are potted in a water-resistant casing, which is a great feature. They are essentially water-proof.
    There are two antenna. I run mine with the main (longer) antenna as far out of the boat as possible, and I just lay the secondary antenna inside the cowling. Seems to work great. The attached pictures show the initial testing version, where I ran the second antenna outside the radio box and down the side, but the released version I just coiled the second antenna inside and it seems to work fine.
    From what I've been told, the only official products at this time with Marine support are the DX3S and the MR3000 (that's the receiver itself). Some other radios will eventually be added as we can train, support, etc. Some radios will NOT be upgraded, in particular the old 2.0/3.0 series.
    Darin E. Jordan - Renton, WA
  • Diegoboy
    • Mar 2007
    • 7244
    Very nice indeed
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      Darin, how long is the main antenna?
      Douggie
      • Darin Jordan
        • 8335
        Douggie
        I haven't measured it directly... It's a little over 10" long on the samples I have.
        The actual "antenna" is only the last 1" of wire that is exposed... the rest of the length is really just to give you the opportunity to get that last 1" up as high as you can...
        • Flying Scotsman
          • Jun 2007
          • 5190
          Thank you for the answer. The reason I asked is I have been looking at 2.4ghz systems for over a year and my concern was my existing FM antenna lead lengths are much longer than the wire lengths offered by other 2.4ghz systems. The Spectrum length would allow me to use their RX without modification to my existing antenna placements
          Douggie
          • Steven Vaccaro
            • 8723
            Thanks for the info Darin.
            Steven Vaccaro
            • Ub Hauled
              • Aug 2007
              • 3031
              I always wondered why nobody invesed in a marine version Rx... specially one with a small footprint.
              Airplanes Rx are among the smallest ones I have seen, there should not be a reason for a "ground" Rx not to follow the same size... anyway, thanks for the testing Darin.
              • Doby
                KANADA RULES!
                • 7280
                Good to have someone "on the inside" for updates like this.
                Thanks Darin (although I have never had problems with my 7 Spektrum recievers to date)
                Grand River Marine Modellers
                • ghostofpf1
                  • Jun 2008
                  • 392
                  Did I read right??? They made the rx compatible with the air Spektrum and not the ground type ??
                  Steve
                  • Darin Jordan
                    • 8335
                    One more thing I forgot to mention... this RX has parallel connections built into it, so if you are running dual servos or dual ESCs, you don't need a Y-harness... You can see that there are two TH and two ST connections... I'm not sure if the BD (Binding) and the AUX connections are also parallel circuits...
                    The additional connections might account for the larger footprint. Also, Ground or Marine dedicated RXs have different requirements that Air... The signals don't always travel as well over land or water as they do up in the air, so perhaps there is additional power or circuitry needed... Andy might be able to speak to that one.
                    • sailr
                      • Nov 2007
                      • 6927
                      That's great. They needed to do something because Spektrum in boats was not the best combination in the past. Good to see that JR is listening and responding! That's a sign of an informed and intelligent vendor! It's cool you can be involved in the testing. Thanks for the update! The parallel connections is a great feature too!
                      Mini Cat Racing USA
                      www.minicatracingusa.com
                      • Darin Jordan
                        • 8335
                        Just for future reference... JR and Spektrum are NOT the same company. They have cross licensed products in the past, but they are separate and distinct companies.
                        This new stuff is all Spektrum...
                        • sailr
                          • Nov 2007
                          • 6927
                          OK. Always thought it was JR. Didn't know they were separate. Good to know.
                          Mini Cat Racing USA
                          • alvinsmith75
                            • Jul 2008
                            • 635
                            UM, are they $25.00 like Tactic?
                            • Doby
                              KANADA RULES!
                              • 7280
                              Umm,,,probably not
