Hi all .Here you see me building my first Peells boat and i have the hull send out to get laser cut.I would cut my own but I fell off roof in 2003 and have 3 main op and two 3" rod and an neurostimulator install .so I can not use power tool anymore .So first let me say Pete know how to build boat and they are 100% super i have build many boat before .but this is the first time i can build a boat with my 7 year old son and we are enjoying it .So hat off to you Pete .Now here what i did already .I lay out all mark on work bench and made a line down middle then i 5min epoxy the 1/8 stringers which was steamed to bend easily .take So here some picture of it
My peells micro 28" v hull
Tags: None
boat picture
[ATTACH]13441[/ATTACH]
[ATTACH]13442[/ATTACH]
[ATTACH]13443[/ATTACH]
[ATTACH]13444[/ATTACH]
[ATTACH]13445[/ATTACH] -
some other boat
here are some other boat i am working on .and my shop and here you can see my 7 year old son workbench and as you can see i have 12v sander and 12v ROTARY TOOL PICT0017.JPG
PICT0016.JPGComment
Great to see people building hulls. The Dauntless in your pictures took me 3 years of on and off building to complete. Also, it is fantastic that you have a young helper.
DouggieComment
Yep he make my day and i just started The Dauntless 3 week ago and i just did an 48' Dumas pt 109 with a OS 45 engineComment
Hi all .Ok here what i did today i sand the hull and put the side on here some picture of today work .[ATTACH]13490[/ATTACH]
[ATTACH]13491[/ATTACH]
[ATTACH]13492[/ATTACH]
[ATTACH]13493[/ATTACH]
[ATTACH]13494[/ATTACH]Comment
Bob,
Looks great you have been very busy in your shop keep up the great work!! I am running a Feigo 9xl with water cooling and a x438 prop with 6s and I am going to change to 2-4s packs in parallel and prop up a bit,
I have a new hull which will be better for dual jet drives than the Nitro Hunter, I call it the Nitro Eliminator, The front looks similar to the Nitro hunter but I widened it out to 9" and squeezed the thickness down in the back (narrowed the V) flattening out the v in the back considerably.Peter Eells; Fun, and Helping others To Have Fun!!!
http://rcboatsbypetere.blogspot.com/
[email protected]Comment
Hi Pete .Sound good to me any picture of it And yes been working hard just finish 1/8 atlas van line hull and started to sheet your hull .pic coming soon .also i am looking for not so fast set up for my son Nitro Hunter it all balsa wood madeComment
Hi all .i worked on boat today and sheet it and add rail inside to hold down cover and add support to it .So here more picture on what i done .so now i need to thing hard to see what motor to you in this one ? 9xl or 8xl .so now i am going to fiberglass now with 2oz mat .picture are on next post thank allLast edited by kennyrach; 06-20-2009, 09:06 AM.Comment
[ATTACH]13585[/ATTACH]
[ATTACH]13586[/ATTACH]
[ATTACH]13587[/ATTACH]
[ATTACH]13588[/ATTACH]
[ATTACH]13589[/ATTACH]Comment
Hi all Here what i did today .Hope you guy/lady like it so far[ATTACH]13643[/ATTACH]
[ATTACH]13644[/ATTACH]
[ATTACH]13645[/ATTACH]
[ATTACH]13646[/ATTACH]
[ATTACH]13647[/ATTACH]Comment
