Blackjack Baseline Test
  • ApacheDude
    • Sep 2008
    • 83
    So I have been running my Blackjack a few times and figured I should baseline a few runs to get an idea of what improvements I get over time. I bought an EagleTree logger and love it...
    My results for stock setup
    27.4 MPH (via Garmin Fortrex 201)
    16,500 Total RPM
    Motor Temp maxed at 80.6F
    Prop angle set low
    NiMH batteries in fair shape, not new.
    I was surprised to see that this setup was pulling almost 60 amps? 57 on one run and 58 on another run (different day). I have attached the screenshot from the logger to show.
    Comments?
    Boats:
    Proboat Apache 24
    Proboat Blackjack 26 Brushless
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    Are you sure you didn't install an anchor? LOL, J/K
    For those of us that do not have a data logger, this is great info. Are you using the stock prop?
    • ApacheDude
      • Sep 2008
      • 83
      Yes, stock prop. I thought it would be in the 30's but I think the batteries are the weak link at the moment. Plus I am going to adjust the prop angle up.
      My goal is to do one thing at a time, make a few runs, and compare.
      Boats:
      Proboat Apache 24
      • Steven Vaccaro
        • 8720
        What packs were you running? 28mph is about on par with a 12 cell nimh system.
        On the next run log consider adding the voltage also. That will give you an indication of cell quality.
        Steven Vaccaro
        • ApacheDude
          • Sep 2008
          • 83
          2 Trinity 6 cell packs. After the holidays I am going LiPo. Just having a tough time trying to figure out which packs are going to suit me.
          I also logged the voltage and noticed large drops but I figured that was part of the large current draw. I think it dropped to around 10 volts under heavy loads. I can post that graph for this same run if needed. What should I be looking for? What indicates a better pack vs. a crappy set?
          Boats:
          Proboat Apache 24
          • Steven Vaccaro
            • 8720
            A better pack under load will have less of a voltage drop. If you are dropping to 10v with nimh a set of lipo will easily give you 3-4 volts more. Which directly translates to at least 3000 to 6000 more rpm. You will be amazed at the speed difference.
            Steven Vaccaro
            • Meniscus
              • Jul 2008
              • 3225
              ApacheDude, you are going about this the right way, trying one thing at a time. Its nice to see someone that is patient enough to do just one thing at a time, test, log, and best of all, share their experience and knowledge gained.
              I wish I could stick to the trying one thing at a time mentality. LOL
              • scoota
                FE DOWN UNDER
                • Dec 2008
                • 409
                With a stock drive system apart from relocating he water pick up ,im running a Feigao 11L motor , found the XL motor over kill & an ETTI 125 amp speedy with a x440 prop a cheap way of getting speed out of that hull rides well & has been bullet proof . I have been GPs speeds between the 47 & 49 mph mark .....as for running high amps make sure the drive system is not pushing up motor shaft to hard or against the drive cable tube that can cause extra load on the system & make sure the flex drive is well lubed !!!!
                UL1- 1515 castle/neu / 240 swordfish
                SV27- with UL1 running gear
                33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
                • Meniscus
                  • Jul 2008
                  • 3225
                  Cool, what are you testing next? Your post is one day after Christmas...and it looks like you have your lipos.
                  A true FE boater!
                  • ApacheDude
                    • Sep 2008
                    • 83
                    I think you are confusing my posts with scoota?
                    but... I did order my lipos!!! Could not pass up the deal from cheapbatterypacks.com this time around. rclipos.com did not come close for packs in this range.
                    Next up to test in order (hopefully this weekend):
                    Prop angle
                    switch to lipos (Elite 2s 4800s)
                    Octura x642
                    Motor timing
                    If this does not satisfy my needs then I am on to:
                    Fullers or similar hardware
                    new props (any suggestions after x642?)
                    3S lipos
                    New motor
                    I am quickly becoming a FE addict with no desire for a cure...
                    Boats:
                    Proboat Apache 24
                    • Meniscus
                      • Jul 2008
                      • 3225
                      My mistake, LOL!
                      Hardware: I'm thinking about trying the Head of the River (HTR) hardware on mine.
                      Prop: My Blackjack is running well on a Prather 220.
                      • ApacheDude
                        • Sep 2008
                        • 83
                        Run 2
                        OK, went to the model boat pond today here in San Diego. Nice day and a good run.
                        Today's mission was to test the new lipos. I will admit that I adjusted the prop angle up a bit as well, so I changed two things from my last run. Attached are the voltage drops during the run. NIGHT AND DAY difference with lipos. I was using Elite 2S, 4800's.
                        Previous run was 27.4 MPH
                        Todays run was 32.4 MPH
                        Motor temp 86.9
                        Max AMP Draw : 68.75!!!
                        WOW. The boat was running great. It held the voltage much better than the NIMH runs. I knew I would be, but I have to say it: I AM SOLD ON LIPOS.
                        Next up: Motor timing set to high.
                        Then my X642, sharpened and balanced.
                        Then Fullers
                        then... ?
                        Boats:
                        Proboat Apache 24
                        • rc123
                          • Sep 2008
                          • 31
                          First this is a great post so keep it up :)
                          From what I've learned in the last few months with the BJ
                          - X642 prop on the current z drive may be a challange I've just managed to put an X640. Still it's worth I was doing close to your current speed on 4200 nimh with the X640
                          - New hardware - may look into the Head of River stuff I think it's a copy. I've got the Fuller one (different from the one Propnut has) and it looks quite the same. The quality should be different at least the price was..
                          Next for me was a larger esc and 6s lipos and then my fishing skils improved :)
                          Then bigger and faster I think are the key words...
                          • Meniscus
                            • Jul 2008
                            • 3225
                            Note: the Head of the River hardware has water pickup on both sides of the rudder.
                            Again, this is what I was going to grab in the future for my BJ. If I'm not mistaken, User: "Spot Me 2" has had this hardware in the past and could probably attest to its quality. Send him a PM, unless he happens to read this and he can confirm or deny that he has owned.
                            • rc123
                              • Sep 2008
                              • 31
                              So it's better to search the forum before you buy
                              One thing still is that the prop shaft and strut is on 4mm but they may work with the 3/16 props.. (based on my limited knowledge)...
