Miss Vegas Conversion Done 4 Months Early
  • Doby
    KANADA RULES!
    • 7280
    Here are some pics of my latest attempt to shorten the Canadian winter.
    Ready for the water. SV controller, 9XL on 4S and a really neat water-cooled motor mount
    Grand River Marine Modellers
  • Raydee
    • May 2007
    • 1603
    HAHAHAHA, I have a PT SS21 that I started but decided to hold off until January. Man our winter is wy to long.
    Team Liquid Dash
    • AntronX
      • Jul 2008
      • 333
      One more reason to like Florida, but i miss snow... (i am from the north)
      • txboatpilot
        • Oct 2007
        • 1494
        Looks nice Bro!
        How is it's big brother doing?
        What prop are you going to run on this boat?
        Happy Holiday's
        Rich
        Nothing like keeping you lipos warm and your prop wet!!
        • Fluid
          Fast and Furious
          • 8012
          Hey Rich, what're you working on? We won't have another HOTMBC race until early January so we're all buildin' new boats. I have a new P Sport Hydro and LSH, and will build a new LSO cat later in January. Sure wish we all could run together again soon....
          • Darin Jordan
            • 8335
            Looks neatly prepared...
            One comment... keeping the weight low will almost ALWAYS be a benefit to the handling of the boat. Your boat will handle better if you move the ESC down onto the deck in front of the motor. It's WAY up there right now, and it is a substantial piece of weight at the speeds you'll be going.
            It'll be interesting to see how the SV27 ESC holds up to that motor/setup...
            Darin E. Jordan - Renton, WA
            • Doby
              KANADA RULES!
              • 7280
              Hi Darin;
              I'll take the speed controller location under consideration. I have been using that motor / controller combination in 3 different boats for almost 3 years now with no issues at all. I pulled the combination out of my 1/12th Llumar hydro and its a tad smaller, but also a bit heavier so I anticipate no problems, always nice and cool.
              I will start with the standard SV 3 bladed prop (which got the Llumar to the mid 40's,,,although a bit unstable due to the batteries being way to far back). From that prop, I'll start experimenting
              In the Vegas with the LiPos up front, it balances out about 1.5 inches from the back of the sponsons so it should be a lot more stable
              Hi Rich;
              Good to see you back and about!
              The 1/8 Llumar is not bad, the weight distribution is a n issue that I'm working on over the winter. Hey, did you get the cooling jacket back, I sent it about a month or more ago
              As for prop suggestions, I'm open to inputs.
              • Diegoboy
                • Mar 2007
                • 7244
                Is she still on the 1/8 prop shaft? Or did you upgrade to the 3/16?
                • Doby
                  KANADA RULES!
                  • 7280
                  3/16th.
                  • Fluid
                    Fast and Furious
                    • 8012
                    With a strong ESC, sport hydros of similar size and weight often pair the 9XL with an m445 to m645 prop. With the SV controller I have no idea, but I suggest around an x442 to start.
                    • killjoy781
                      • Jan 2009
                      • 43
                      what do i need to convert her? is there an easy way? like just taking the electronics off another model? i like nitro, but i dont like it for boats.....i hate when my engine stalls out in the middle of the pond.
                      • Gerwin Brommer
                        • Dec 2008
                        • 918
                        Funny, a rc-box in an electro-boat ?????
                        Get rid of it !! (and loose the weight)
                        • calcagno45
                          • Mar 2008
                          • 1006
                          Doby, What hardware did you end up using on back? I know you changed to 3/16 propshaft, so which strut, and same rudder or different?
