Difference in a X and Y series prop
  • ReddyWatts
    • 1711
    It looks like the tongue is longer on the Y series prop. This is just the opposite from the M series, that has a shorter tongue than the X. Can someone explain what performance difference you should expect to see from a longer and shorter prop tongue?
    ReddyWatts fleet photo
  • Fluid
    Fast and Furious
    • 8012
    Tom has told me repeatedly that the only difference between the X and Y props is an additional 10% more pitch on the Y....blades are the same. You can expect a bit more speed with the Y and a bit more lift....usually. I find the M545 gives slightly more speed than the M645 on my LSH; the M545 is a Y545 without the tongue.
    The tongue is lower pitched than the rest of the blade, and it hleps the boat to get up on plane. I have no problem getting any of my boats on plane and remove the tongue on all my X and Y props - I prefer to buy M series from the start if I can. You will usually see a bit more speed from a prop with no tongue.
    • ReddyWatts
      • 1711
      Tongue
      The longer tongue helps accelerating out of the hole and a shorter tongue will get a higher top speed. Thanks!
      The previous picture was an optical illusion. I layed the props on top of each other and Fluid is correct, no difference. A Y537 prop is really a X537. So why didn't they just name them X437, X537 and X637 props. It would be a lot less confusing. Y? Y? Hmmmm.......
      How big is the guy that did that? I am looking for him. J/K
      • Fluid
        Fast and Furious
        • 8012
        He's the guy in the middle. Now don't you feel silly!
        • ReddyWatts
          • 1711
          I still wonder what he was thinking when he named it Y.
          • franktcs
            • 2
            Anyone have a picture of a tongueless prop
            • RMZDADDY
              • 379
              Here's a pic of an X645 (on your left) and an M645. The M series has the tongue cut down.
              • ReddyWatts
                • 1711
                X-M props
                Here is another picture of the M and X series props. X is on the bottom. You can see the difference, it is not alot.
                They are both factory Octura M and X 447 props.
                • franktcs
                  • 2
                  Does anyone remove more tongue than that? And what will be the effect?
                  • GeoRXT
                    • Jan 2008
                    • 45
                    Im sorry guys, I am new to this and by the pictures I really cant point out what the tongue is...? And how do you remove it?
                    • ED66677
                      • 1300
                      the tongue is the "front" part of a blade that is the closest to the shaft look at figure 2 here
                      Emmanuel
                      I'm french but I doubt I really am!
                      http://pagesperso-orange.fr/pleindetrucs/
                      • GeoRXT
                        • Jan 2008
                        • 45
                        Can you do this on the stock prop?
                        • H&MWill
                          • 623
                          Is it plastic?
                          Many issues!!!
                          • GeoRXT
                            • Jan 2008
                            • 45
                            Originally posted by H&MWill
                            Is it plastic?
                            Yes sir it is...
                            • lonewolf
                              • Jul 2007
                              • 658
                              Here is a place to read up on props. There is alot of other info at this site also.
                              Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
