I have been giving the opportunity to do some battery testing. Thanks to Paul at Venom RC I was able to get my hands on some nice venom packs to see how they stand up against other popular packs. I figured no better boat to try this out on then the new Motley Crew from aquacraft. The rtr market is typically the biggest so this looks like a good starting place. This will be a ongoing test, and after some use on milder amp draw setups I will put these in some of my higher amp draw setups. Will be using a eagle tree data logger for data and will be monitoring voltage drop, amps, loaded rpms, wattage and maybe a few other things with it. Speed will be a standard Garmin GPS. Not the best but will work. The real true data will come from the eagletree. For now this will be a good starting place. I am trying to keep the mah and c ratings similar to tested packs but that's kinda hard to do. The batteries i will be testing are listed along with pros/cons.
My MC ETA is Tuesday 5/17. I will be out of town this weekend, but testing will begin when I get back. I plan on running stock at first then we will drop the new power package that I have for the boat.
