Waterproofing and rx water test.
  • Diesel6401
    Memento Vivere
    • 4204
    Quick vid on how I waterproof my electrics and I drop it in water to show it works. http://www.youtube.com/watch?v=fcSTB40mjsE sorry for the video, cell phone vid and lost HD when I went to edit it.
    - Diesel's Youtube
    - Diesel's Fleet
  • dascoadams
    • Feb 2011
    • 128
    Thanks for the video diesel...harbor freight bound
    • Jeff Wohlt
      • Jan 2008
      • 2716
      I use the same thing...works well. Like the foam block tip. So when are you dunking the ESC? :)
      www.rcraceboat.com
      [email protected]
      • Diesel6401
        Memento Vivere
        • 4204
        Thanks hopefully it works out for you
        I have had the 120's pretty drenched without any issues so I know it worked in the field, as far as sticking the 200 in the bottom of the glass though, not sure if my ***** are big enough just yet lol. Maybe down the road I will try somthing like that.
        - Diesel's Youtube
        - Diesel's Fleet
        • sailr
          • Nov 2007
          • 6927
          Where did you find the CLEAR? All I can find is black. Danged ugly ESC when you're done!
          Mini Cat Racing USA
          www.minicatracingusa.com
          • dascoadams
            • Feb 2011
            • 128
            Ace hardware
            • SweetZ28
              • 1322
              Good stuff!
              Cool thing about the cheap 2.4 flysky RX's they are waterproof and work under water out of the box I just give them a coat of corrosion X so nothing gets corroded.
              WWW.PPRSLOTS.COM
              • BLAZE WON
                • Sep 2010
                • 43
                great vid, thanks for sharing. are there instructions on the can that tell what the heat parameters are. as you know when you push the envelope on the speed control they can get very warm.
                • hebner
                  • 647
                  Harbor Freight has the clear.
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    Like mentioned I picked mine up from Harbor Freight, I don't think it was more the $3-$5 per can. I picked up 2 cans a while back.
                    The operating range for the brush on stuff is -30F - 200F, I will have to find the specs for the spray when I get home and look at my can.
                    - Diesel's Youtube
                    - Diesel's Fleet
                      • 9488
                      I think I got mine at Wally Mart
                      I love the fact that you don't see it at first glance when you use the stuff
                      • Mel279
                        • Dec 2008
                        • 857
                        Diesel6401
                        have you test it in saltwater?
                        • Diesel6401
                          Memento Vivere
                          • 4204
                          Originally posted by Mel279
                          Diesel6401
                          No I have not. Not sure how she would hold up, salt destroys just about everything unfortunately
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • Mike whiting
                            • 120
                            I already got the rx wet is there anything I can use to clean off corrosion to make it work again if it will work again
                            • martin
                              • 2887
                              Corrosion X. Martin.
