Hi, i have a 380 7xl motor sitting in my cupboard that i havent even used yet. Im not sure how it would go on 3s with a 35mm prop. im not game to use it cause im sure it will heat up too much. i dont have much money to spend so i was thinking on going to one of these motors! i would only be able to spend about 30 on the motor cause then i have a watercooling jacket on top of that!
I will run it on 4s with a slightly larger prop than my stock 35mm. will that have any heat issues with a larger prop and what kinds of speeds would we be talking with that motor ?? or if you have any other cheap motor options for around 30 that would help alot.
thanks alot
matt
thanks alot
matt
