New Hull from HK
  • domwilson
    Moderator
    • 4408
    New Hull from HK
    New hull from HK.
    http://www.hobbyking.com/hobbyking/s...dProduct=15235
    Now let the comments begin....
    Government Moto:
  • martin
    • 2887
    Thats an Osprey with no motor etc. Thanks Martin.
    • Diesel6401
      Memento Vivere
      • 4204
      Got the email this morning, looks good. Thinking about pulling the trigger on this thing. I want to use a 4082 1450kv on 5s & 6s. Anyone think that motor in this hull will work? Hoping I can get buy with 5s1p or 6s1p, goal is mid 40mph.
      - Diesel's Youtube
      - Diesel's Fleet
      • ray schrauwen
        • 9471
        Sounds like a nice setup and 40 mph is doable. If I didn't already have a 40" mono to build, I would have grabbed one.
        At that price I can't even get the hardware !!!!
        Shure makes Open mono open right up to those with small wallets.
        Their price is too low, they are undercutting the whole market... Oh well, I don't need one. Hull only for that price would be decent but, hardware too? HOR & DF must get totally PEEVED over this stuff....
        • Kaz the Minotaur
          • Jan 2008
          • 34
          Shipping to USA is $52 though. Still seems like a good deal.
          What about a CC 1717 1580KV on 6S?
          • martin
            • 2887
            I think you may see mid 40s on 6s but not on 5s, Forescott built an Osprey (same hull) recently. I think its under the build section & video section. He used a Leopard 5692 motor on 6s & i think from memory he got around 50-52mph. Thanks Martin.
            • gultch
              • Jan 2011
              • 63
              just pulled the trigger on this hull looks good i to have a 1717 and would like to hear any opinions about it on 6s and prop sizes thanks
              genesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progress
              • Make-a-Wake
                FE Rules!
                • 5557
                I got 55 mph out of my 1717 6s setup in my 39" mono of very similar style.
                • Diesel6401
                  Memento Vivere
                  • 4204
                  I just pulled the trigger on this hull. I ordered slow poke shipping which was $50 and ems was $80. This is going to sit for a little so I had no reason to spend an extra $30 on shipping just to look at it on the shelf lol. I will try the 4082 like I mentioned and a swordfish 240hv.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    Hey Diesel..................i bet an x448 would get you 50.........those 4082's are very torquey
                    • b.mcdaniel.2009
                      • Sep 2010
                      • 1641
                      A 4082 would definitly push that light hull into the 40's Diesel6401....Remember my 4082 in my Genesis went 58mph on 6s with a junk Carbon prop.....
                      ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
                      • Diesel6401
                        Memento Vivere
                        • 4204
                        I have a x447 that is s&b and detounged and a x447/3 s&b I plan on trying out. I think that should work ok don't ya think?
                        Good to know.
                        I can use the stock mount re-enforced of course, for the 4082 motor which is why I wanted to go that route. I didn't feel like custom mounts and adding rails and all of that. I have enough projects taking time so i'm praying this should be a pretty easy build. I assume by the picture the hardware should be installed at least I hope it is. I should just need to drill out the 4mm bushing add a 3/16 bushing and use a .187 3/16 flex cable. At least that's the plan. I will re-enforce all of the other mounts as well.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • b.mcdaniel.2009
                          • Sep 2010
                          • 1641
                          Good to know.
                          Yep stock mount will save time and money for sure... I just moded my a little with the 4082 and even with that 1717 in there know....I think the x447 should be about perfect with that motor... What esc are you planning...Maybe Go with a 240lv
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            I don't know yet. If I ran 5s I think I could get by with a seaking 180 or a swordfish 200, but I know I am going to want to run 6s every once and a while. If I ran mostly 6s I would get a swordfish 240. Not sure what I want to do. I don't want to rely on the seaking 180 or sf200 for 6s all the time, but the jump to the HV is pretty big in price.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              I think the 447/3 would be perfect.
