This is my Titan 29 bought used here on this forum.
Before running in the water I have tested it in the bath tube and discovered this leak. Every 3 seconds one drop goes inside the boat, is it normal? I think it could be a problem if the boat have to be rescued in the middle of a lake or far away in the sea.
The shaft is a wire drive, is it normal with wire drives?
What should I do?
What should I do?
