Genesis Twin
  • mudl
    • Aug 2008
    • 159
    Genesis Twin
    Hello
    here a video of my HK Genesis modified to twin drive.
    bye
    mudl
  • Alfa Spirit
    • 2131
    Very nice speed, setup is unusual but the Genesis works fine
    I have a question about autonomy (run time)
    • mudl
      • Aug 2008
      • 159
      Hello
      runtime is about 6 minutes with octura x442
      with octura x447 i don't had tested
      bye
      mudl
      • ggcrna
        • Apr 2010
        • 37
        Hi, how long is your Genesis hull?
        Thanks,
        Glenn
        Awesome run!!
        • mudl
          • Aug 2008
          • 159
          Hello
          the hull is 94 zentimeter and the complete boat with drives and rudder is 102 cm.
          bye
          mudl
          • Alfa Spirit
            • 2131
            Hi Mudl,
            You have a good experience with the Genesis so I need your advice, do you think that the hull is strong enough stock or does it need to be reinforced with carbon layer?
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              Re inforce it. Youll be glad you did.
              • Alfa Spirit
                • 2131
                I know that the result is very nice, I did it in a 32" cat hull (with bulkhead)
                For the Genesis, I will build a bulkhead for sure, but carbon reinfoce is heavy, what do you think?
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3278
                  Do it. Weight isnt a bad thing to a certain extent.
                  • Alfa Spirit
                    • 2131
                    If I don' t reinfoce with carbon may be I will regret, thank you
                    • mudl
                      • Aug 2008
                      • 159
                      Hello
                      the original is stron enough up to 120 kmh.When you want to drive faster i think it is very importend to reinforce it with carbon or carbon/kevlar
                      bye
                      mudl
