I just got in my new Geico Cat. Please check the direction of the flexcable. Mine came in with clockwise rotation cable. Counterclockwise is what the prop needs.
Just a Heads Up!!!!
Do you think this is what could have caused the issue on the other thread with the flexcable being seized in the teflon? Mine should be here soon, I ordered monday from HH so soon as I get it I will for sure check mine. I normally always check the lube on the shaft and the hardware when I get them.
Just a Heads Up!!!!
Awesome catch - I am taking mine out tomorrow for the first time. Just to be sure, what is the best way to tell it is wound counterclockwise?
You should be able to see some of the cable hear the coupler on the motor... The prop should rotate to the left. If the rotation of the strands around the cable are going counter-clockwise and you move down the length of the flex, they are reversed (right-hand) rotation. If they are clock-wise, they are standard, left-hand rotation.
The strands should be in TENSION when the prop is rotating the correct direction, tightening the cable wrap. If it's reversed, it will be trying to unwind the cable wrap, making the cable a larger diameter, and seizing in the stuffing tube, if not outright breaking.
I just put together a quick picture to illustrate...
That is what I thought as well but I wanted to be sure. Thank you for the illustration. I will check when I leave the office and report back to this thread ASAP with my personal findings. My fingers are crossed...
DAMNIT! Mine is reversed too - now what?
Anyone else?
So some are correct some are not. Is their anyway to narrow it down to a certain shipment or location, tth and airman where did you guys purchase from? I bought from HH, but haven't received it yet. I will list my findings asap.
I live in Brooklyn Park, MN and bought mine at Hobbytown USA and they purchased their lot from Horizon Hobby directly. I can't get through to HH or PB right now via telephone.
Got ya, I suppose HH would ship directly to individuals & sellers. Maybe it's a hit or miss, luck of the draw thing. Crazy that happened. I'm anxious to see what mine is.
