Active canard
  • TotalPackage
    Banned
    • 601
    Active canard
    Sorry guys I had to show you this http://www.youtube.com/watch?v=lnauNm1qOsA
  • andym
    More Go Than Show Prop Co
    • 2406
    Would be nice to see the rest of it.
    • m4a1usr
      Fast Electric Addict
      • 2038
      Its been a project for many who want to effect realistic control of the aerodynamics. But none have been able to make it work effectively to date. Still, its nice to see those wanting to break thru with new ideas and techniques. Someones going to make it happen. Just not sure when.
      John
      Change is the one Constant
      • drwayne
        • May 2008
        • 2981
        Full size Unlimiteds use this idea .. must work because most all have them..
        Read somewhere of a gyro used in an rc applet... no idea if successful
        perhaps we will see this example running on water ???
        vid ?
        W
        • TotalPackage
          Banned
          • 601
          Perhaps I could get a loan from the ones so impatient lol. Just had a kitchen house fire last 2 week ago; 8 grand of damage. I dont think it all that hard personally. The flap could easily be coded to shaft speed. The more speed the more downforce applied by the flaps. Or more simple is a default setting for straights and a ir shutter on the rudder arm that adds downforce and puts the sponsons down on the water flat in the right turns for better cornering.
          Dont know about a gyro but an xyz sensor and a microprocessor might fascilitate anti-blowover.Thers a certain bloke out there that coud help with setting up the excel data bases to paste and copy into microprocessor for such an endeavor. One day maybe he might go insane temporarily and speed up this process then Ill be glad to show video. I cant run the boat till perfect cause it will get severely critiqued on ose, No doubt.Im not really into failure just not my thing.I will likely never build another scale boat unless it has canards on it. They dont have to be active they can be static consisting of an upside down wing profile. The person who designed the canards for the real thing must have had intentions for the canards to bring front sponsons out of the water versus holding them down coz if the intentions were to prevent blowover they are all wrong from the start (rounded on top and flat on the bottom creates lift)! shoud be flat on top and rounded on the bottom then you could probaby lose the flap all together. Having the flap gives the coder some nice option if hes up to the task.The flaps could be used to get up on step quicker as well but it all happens so fast I think that would be more of a novelty to brag about more than really working. But a v-tail mix and some code might effectively reduce chine walk coz it happens in the straights and boats will have time to get some effect from cannard system.
          Glassing bottom in progress then primer then white base . Gimme time!
          • Fluid
            Fast and Furious
            • 8012
            Full size Unlimiteds use this idea .. must work because most all have them..Read somewhere of a gyro used in an rc applet...
            There is a world of difference between full scale and models. Things happen way faster in a model than in a full scale boat, and the driver gets feedback of an impending blow-over sooner than we in RC do.
            The only successful use of controllable canard surfaces I've ever seen was for a SAW nitro OB tunnel. The canard surfaces were controllable winglettes just behind the driver's windscreen and were tied to the throttle channel. At mid throttle they were neutral, and at full throttle they provided downforce. They worked and the racer holds several OB SAW records with them - but I'm not certain they were "necessary".
            The problem with gyros is they don't know the difference between a bounce on a wave and a full scale blow-over - they would over correct all the time and probably with too much delay. Full-scale canard surfaces are used to control the ride attitude, not just to prevent blowovers. The father of one of our club members invented them for full-scale hydros.
            • TotalPackage
              Banned
              • 601
              To my knowledge the father of the modern day turbine powered hydroplane (canards) and all
              was Bob Lucero, the boat : 1980 u-25 pay n pak.The microprocessor I propose operates in mips so in not worried about the speed of the events. The xyz sensor and microprocessor can handle it the challenge is relevant coding.No one out there is running shaft speed recognition and putting it to something useful either that I have seen. Win lose or draw Im gonna try it . If it fails it fails.Anyway just wanted those interested to take a look thats all.
              • AndyKunz
                • Sep 2008
                • 1437
                I tried it several years ago, quite unsuccessfully (but it make a great splash).
                Jay's right. As for speed of the micro isn't the issue - the speed of the sensor (and the ability to differentiate between bump and flip) is a major issue, as well as the speed of a servo and the timing it takes to update one. Using off-the-shelf components is NOT going to work. You need a system designed for the speed of a flip of a model.
                That speed of the flip, btw, turns out that it can be within 1/30th of a second although most are slower. I have video of a flip which literally happened between two frames in a camcorder. You can see the first 180 degrees happening during the first half-frame, and the boat was almost completely upright in the second half-frame (using standard interlaced NTSC). In comparison, the frame rate to servos is about 20ms (1/50th of a second).
                If you're going to work on this, I wish you good fortune. You'll have a lot of fun rowing and learning. Take it in stride - Edison had 100's of failures for every success. If you succeed, you'll have fame and fortune.
                Andy
                Spektrum Development Team
                • TotalPackage
                  Banned
                  • 601
                  I wont be doing any rowing sorry, I got motor guide lol.
                  • drwayne
                    • May 2008
                    • 2981
                    Andy
                    Im sure most everyone who has run a scale hydro has dreamt of functional active canards.
                    I sure did with my hulls ... several lucky saves when they 'launched', with rapid deployment of PANIC on the trigger finger.. ... and several not so lucky endings'
                    Ride attitude is the main goal in fullscale.. the ability to get the ride pads out of the wash early can remove a few seconds from a lap time .. important stuff !
                    With the abundance of off shelf miniature sensors , this attempt could herald a new era to our rc scale hydros...
                    Nay sayers beware ! .. this members enthusiasm could be shot down by those who have tried and failed ..
                    We learn best from our own endeavours... and if he gets it right ?
                    Im sitting here at the keyboard waiting to see what happens next.
                    Wayne
                    • Fluid
                      Fast and Furious
                      • 8012
                      To my knowledge the father of the modern day turbine powered hydroplane (canards) and all was the late mr. Bob Lucero, the boat : 1980 u-25 pay n pak.
                      Your knowledge is not the best. First, nobody said anything about turbine-powered hydros. Second, it was Jim Lucero, not "Bob". (Jim was alive in April 2009, when did he become "late"?) Joe Taggart used an adjustable front canard surface on his limitied hydros in the 1970s IIRC. The 1980 turbine Pay-n-Pak did not use an adjustable canard surface.
                      Mr Taggart was also the first to put a vertical tail on a hydro in the 1940s (the Tomyann I believe). He did it not to provide stability, but so that other racers could see his boat through his roostertail (which was a lot smaller back in the 50s than they are today).
                      • v-spec
                        Banned
                        • Jun 2009
                        • 940
                        Xfactor is back guess it's time for some interesting reading again!
                        • drwayne
                          • May 2008
                          • 2981
                          Fluid:
                          OMG !
                          Can ya see the sideburns on those geezers ?
                          If I had whiskers like that there'd be an NRA bounty on my head !
                          • TotalPackage
                            Banned
                            • 601
                            I agree it probably wont work.
                            • v-spec
                              Banned
                              • Jun 2009
                              • 940
                              It's neat even if it doesn't work. I think I'd just make it adjustable and stay in certain positions but still controlled with a channel on the radio. I think it would be (more) functional that way instead of trying to overdo it with gyro's etc which more than likely won't give the desired effect.
