Mini Cat Twin Hull Offshore Style R/C Racing Boat (820mm)
Specifications.
Hull length: 820mm
Width: 240mm
Weight: 1000g
Hull Type: Fiberglass hydro-plane
Motor: 2 x B2848-2636kv water–cooled brushless
ESC: 2 x 50A watercooled
Prop: Carbon-reinforced plastic 2 x D36*P1.4 3-blade
Driveline: Flex-drive
Hardware: CNC aluminum strut and rudders
Battery: 2 x 11.1v 3000~4500mah Lipo (Not included)
Channel: 2ch
Servo: 1 x standard size servo (Not included)
Looks like an exact replica of King of Shaves by Venom just different motors and color.
1/2 the price compare to the King, less radio and servo, not bad at all.
Also don't have to wait till mid September to order one.
The battery tray don't seem to be as well designed as Kings, specially if you want to remove it, also the ESC only 50amp, so limits upgrade potentials.
King seems to include Hobbywing 60amo ESC, they are probably better the no-name 50s in his version.
Specifications.
Hull length: 820mm
Width: 240mm
Weight: 1000g
Channel: 2ch
