spec tunnel
  • Chuck E Cheese
    • May 2008
    • 1684
    spec tunnel
    here are a few clips of my spec vission craft tunnel. running ul-1 with turnigy 5000 40c 4S, 40x53
    it was windy and first runs so i need a little set up but i was verry happy with it so far
    see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
  • Kris Flynn
    #2 Bench Racer
    • 229
    Hey Chuck,
    Boat looks like it is getting along real nice. you need to try a 42X55 now
    Kris
    • Darin Jordan
      • 8335
      Originally posted by Kris Flynn
      Hey Chuck,
      Kris
      YUP! Backcut about .070 or so...
      Darin E. Jordan - Renton, WA
      • Chuck E Cheese
        • May 2008
        • 1684
        it is allready on order..... could you please explain the .070.... is that the measurement on the hub to the tip of the blade or along the entire blade?
        how low are you running the leg on the vision? mine is the bottom of the bullet even with the sponson, so the center of the shaft is about 3/16 above...
        • Kris Flynn
          #2 Bench Racer
          • 229
          try going up 1/16" at a time...mine has an OS lower and runs a bit over 1/16" under the bullet
          Cheers
          Kris
          • rchippie
            • Jan 2010
            • 567
            My VS-1 runs with the bottom of the prop shaft, 1/8 of a inch above the sponson & level. I use a REK lower unit with a balanced & sharpened 42/55 grim prop on 4s with a UL-1 motor.
            • Chuck E Cheese
              • May 2008
              • 1684
              not all that impressed with the 42x55 over the 40x53. i put a small bar cut and s/b the prop. i think i need to cut it more. i was thinking of detounging it some to see if i can get some rpm out of it. the temps were similar and speed nothing to speak of over the smaller one. i will work on the 42x55 some and post my testing results.
              • Chuck E Cheese
                • May 2008
                • 1684
                ok, i take it back. i did a little work on the 42x55 and this thing was flying today. i did a bar cut and detounged it, still need to take a little more off but i had big improvements today... i will take some more video when i get it dialed...
                • rchippie
                  • Jan 2010
                  • 567
                  Originally posted by Insaniac
                  I have been running an REK lower on a VS1 and haven't been able to adjust the hull to my satisfaction...it keeps spinning out.
                  I ordered an OS lower as the hinge pin is inside the rear of the sponson as recommended by Aquacraft.
                  I don't have that problem at all . I'm also using a Hi-Jack motor mount if that makes any difference. I set mine up once & have not had to adjust it at all. My esc & servo are in the back, & the wire side of my lipo is about 9 1/4 inches from the outside edge of the sponson.
                  • Chuck E Cheese
                    • May 2008
                    • 1684
                    ran it today and finally put the eagle tree in her. using the same ul-1 motor, cc120 and 5000mah on a bar cut 42/55 data was: 45mph, 112 amps, temps: battery 114, motor 104, esc 118. this was the same pond as the videos with exactly the same set-up.
                    what kind of speeds are the rest of you getting from spec tunnels? i know if i work the prop a little more and go to a bigger body of water it is good for a few more mph.
                    • AlanN
                      • Mar 2008
                      • 334
                      45 is almost there. Have ran low 50's but it gets difficult to handle at those speeds. Vs-1 Hull with REK lower end, cc 120, 5000 Hyperion G3's, 1614 chopper.
                      • Chuck E Cheese
                        • May 2008
                        • 1684
                        i know how to handle the speeds, my mod FE tunnel runs 60
                          • 9488
                          Do you think it ran better than with the 40/53 ?
                          • Chuck E Cheese
                            • May 2008
                            • 1684
                            no the 42x55 is better for sure... just needs a little more work. i got it to where it is and stoped playing with it. the boat sat for a while untill i ran my mod tunnel last week. got hooked on the tunnels again. they are the funest most chalanging boats to drive. plus i like sticking it to the nitro guys. they are all amazed at the fact that i can get the fe's to run as good as they do.
                            • Kris Flynn
                              #2 Bench Racer
                              • 229
                              peaks of 112 amps? Sounds ok. but if that is average, then a bit high
                              Now you going to make it to the WORLD TUNNEL CHAMPS next year? hope to race you there!
