Scratch build 37" Mono
  • F1 madness
    • Feb 2010
    • 788
    Alrite guys built this 1 a while ago and decided to get it ready for the water.
    iv got all the hardware now and just putting everything in place,gonna run 6s on a 1088KV scorpion motor,and prop sizes 38mm,40mm,42mm.
    The only thing im struggling with at mo is finding the CG,were would you sat it is roughly,never built 1 of these before,so all new to me.
    http://s577.photobucket.com/albums/s...79/F1%20boats/
    Daz from sunny England
  • F1 madness
    • Feb 2010
    • 788
    Heres some shots of the inside with Motor,batterys & ESC,my CG is 9 1/2 inches from transom at the mo is this ok or does it need to be further back:rolleyes:.
    The rails inside are not glued in yet as iv got do some cut outs for battery straps and to get the motor mount further down,stuffing tube will be in place once i know where to mount everything and can cut it to lenght.
    • F1 madness
      • Feb 2010
      • 788
      Some shots of the rear with some of the hardware in situ:
      • Alexgar
        • Aug 2009
        • 3534
        i always set mine at 33% length of boat divide by 3 and that distance from the back so 37/3 =12.333 so aprox 12 3/8 im my opinion and minor adjustments can be made by shifting the batteries forward or back on velcro strips
        • F1 madness
          • Feb 2010
          • 788
          Cheers bud,will try that
          • sailr
            • Nov 2007
            • 6927
            25-30% from the transom.
            You are going to have to put that flexshaft in a tube! The way it is it will flop around and beat the boat to death...destroying it from the inside out!
            Mini Cat Racing USA
            www.minicatracingusa.com
            • Make-a-Wake
              FE Rules!
              • 5557
              Are you running those batts in parallel...............if in series, which i suspect, you will possibly have some hot batts at only 64a continuous discharge.
              • F1 madness
                • Feb 2010
                • 788
                only used that small piece to line up the through the transom to the strut,im just installing the rails and longer stuffing tube along with a brace.
                only using these for layout got some bigger rating batts on order,but will be run in series
                • F1 madness
                  • Feb 2010
                  • 788
                  Took a couple of pics and worked out CG:29%
                  Pic of CG:28%
                  Which do you think will work best?
                  Just trying to work out to move rudder starboard side
                  • F1 madness
                    • Feb 2010
                    • 788
                    well some pics with everything in and CG at 29%/11" from transom, and some adjustments:
                    Just gotta add some resin round the water inlets/outlets,motor mount and stringer-rails & stuffing tube,and fix in servo mount.
                    Then complete the rear hull deck after modifying it to mount strut and fill in the holes
                    • Jesse J
                      scale FE racer
                      • Aug 2008
                      • 7116
                      Sweet work man, really dig the looks - very sinister. can't wait to see her wet!
                      "Look good doin' it"
                      See the fleet
                      • F1 madness
                        • Feb 2010
                        • 788
                        Cheers bud,i cant wait either should be fun.
                        • screwball
                          • Jul 2009
                          • 464
                          is their any chance of me getting a set of plans for this boat, i really like it.
                          • F1 madness
                            • Feb 2010
                            • 788
                            alrite bud leave it with me as i designed and built this hull myself.
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              yeah this thing is awesome!! is that a head of the river strut rudder setup?
