Well iv finally got the rest of my bits together,and now my F1 24" is finally ready to get wet.
Its running a hobbywing 3600 kv water cooled motor that iv mounted on a modified original dolphin outboard,up graded flexi and ballrace sealed bearings on stub shaft and twin cooling pick ups,hobbywing 60amp esc,futaba 3004 servo for steering with twin cable (push-pull system).Lipos are overlanders 3200 mah,20C 3s 1p,11.1 volt.Iv got 3 props to try 31mm,34mm,38mm.
But will probably just stick to the 31mm.Weather depending will try tomorrow and hopefully get a vid or 2.
