New Turnigy Digital Charger Balancer
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    I just got one of the new Turnigy chargers and tested out on my new 2 x 4S Turnigy LiPo's. Works great, easy to use and has great digital display.
    On the negative side, cooling fan is a little noisy but it sure moves the air very well inside of it.
    Anybody else has one and would like to share their opinion?
    Robert
    Canada
  • eboat
    • Aug 2007
    • 693
    If you have a big enough power supply can you charge 4 4S lipos at 5 amps each ??
    • LiPo Power
      • May 2009
      • 3186
      Next time I will plug 4 x 4s and let you know.
      I think 4 x 4s woul charge at 3Amp
      Robert
      Canada
      • JimClark
        • 5907
        How acurate is it and what voltage is it charging to?
        Jim
        Billy Graham
        • teach
          • Jun 2008
          • 509
          Should charge all 4 packs at 3.4 amps. I only have 2s packs so the 3.4 amps is from what others have claimed. It's just 4 smaller charges built into one box. They all work seperate from each other. I have charged all 6 of my packs at 6 amps although I only got the one balance adapter. So if you buy one please remember to get a few more.
          On the first go around the balancer was dead nuts. 6 packs all came in from 4.19 to 4.20. Verified using my voltmeter.
          That fan does make some noise.
          Over all in the very short time I have owned it's been perfect. Who knows on longevity.
          • calcagno45
            • Mar 2008
            • 1006
            It's only 50watts per channel, which limits it to about 3.4amps per 4s pack.
            • eboat
              • Aug 2007
              • 693
              That is what is was wondering about
              Looks like a good charger but to try and charge the 5000 packs will take longer when you can only go to 3.5 instead of 5 amps
              • LiPo Power
                • May 2009
                • 3186
                ...right, but you charging 4 on the same time!!! Or 4 diferent ones on the same time wthat would not be possible with single or duo charger....
                I made one mod to my charger and cut the bars on the front of the cooling fan. It moves air much easier and I can feel better air flow now....
                Charging 2 4S LiPos this pappy is not even getting worm but extra air flow allways helps...
                I love this charger!!!
                After the weekend I will be testing this charger all possible ways. All my LiPos are charged now and I need to drain them out to before my testing. Will update....
                BDW guys!!! This charger is $99.99 for members!!! Regular price is $144.00
                Robert
                Canada
                • LiPo Power
                  • May 2009
                  • 3186
                  May I please ask how did you figer is 50 Watts per channel?
                  Thank You
                  Robert
                  Canada
                  • LiPo Power
                    • May 2009
                    • 3186
                    Most of my LiPos are 2S so eureka!!! I can charge 4 of them at 5 Amps!!!
                    Canada
                    • 6S HYDRO
                      • 1320
                      50w per channel is listed in the specs, i only have mostly 2s packs too-so ive had my eye on this one as well.
                      • LiPo Power
                        • May 2009
                        • 3186
                        ...got it...
                        Canada
                        • LiPo Power
                          • May 2009
                          • 3186
                          Test Charge # 1 ( New Turnigy 4 x 6S charger )
                          Test Charge # 1
                          4 x 2S, 5000mAh, 20-30C, 7.4V charging at 5 Amp on the same time. Works fine.
                          Charger after 6 minutes only got worm. So fare so good...
                          Next will be to see 4 x 4S batts....
                          Will post...
                          Robert
                          Charging of 4 bateries done in 60 minutes!!!
                          Canada
                          • Meniscus
                            Refuse the box exists!
                            • Jul 2008
                            • 3225
                            That's definitely not something I would leave unattended! I'm glad to hear it's working well for you.
                            • LiPo Power
                              • May 2009
                              • 3186
                              My charging is allways done under close supervision....
                              Canada
