Radio comparisons 2.4 GHZ
  • wizard122
    • 483
    I just want to show some radio comparisons different features and the cost
    Tactic TTX240 2.4GHz 2-Channel Pistol Tx Rx No Servos 79.99
    FEATURES: 2.4GHz technology eliminates crystals, frequency pins and waiting for
    available channels
    Advanced FHSS (Frequency Hopping Spread Spectrum) design avoids
    unwanted interference
    Simple push of a button on receiver binds it to the transmitter and
    that link remains even if power is lost to receiver
    Ideal for nitro or electric powered cars, trucks and boats
    Compatible with a wide range of digital and analog servos
    Built-in fail safe
    INCLUDES: TTX-240 Transmitter
    TR-324 3-Channel Receiver, TACL0324
    Four Cell Battery Holder
    Switch Harness
    Airtronics MX-3 Sprt 2.4GHz FHSS-2 Computer Radio Tx/Rx 79.99
    FEATURES: LCD screen displays digital adjustments and settings
    Four edit keys for setup
    10 model memory
    Dual rate steering
    Digital trim
    2.4GHz 3 channel pistol grip
    INCLUDES: One 3-channel 2.4GHz Pistol Grip Radio
    One RX-371 Receiver
    One Battery Tray
    One Switch Harness
    Airtronics MX-3FG FHSS-2 149.99
    This is the 2.4GHz MX-3FG FHSS 3-Channel Computer Radio.
    Transmitter and receiver only, no servos included.
    FEATURES: Quick binding and fail safe setup
    18 model memory
    Optimum third channel switch location
    High performance non-BEC micro 4-channel receiver
    Large LCD display
    Ideal for all types of model cars and boats
    Transmitter has charge jack for optional NiCd battery pack (95046Z-
    not carried)
    INCLUDES: MX-3FG Transmitter
    92624 4-channel Receiver, AIRL2000
    4-Cell Battery Holder, AIRM4050
    Switch Harness
    Instruction manual
    Futaba 3PM-X 3-Channel 2.4GHz FASST Tx/R603FF Rx 169.99
    This is the Futaba 3-Channel 3PMX Computer Radio with the
    2.4GHz FASST System.
    Transmitter and R603FF receiver only, servos not included.
    The 3PMX is also capable of using the R603FS receiver
    to give modelers special Dual Antenna Diversity (DAD).
    **The 3PMX adds three new features; Four Wheel Steering Mixing,**
    **Digital Trim Step and Adjuster for Crawlers, Monster Trucks**
    **and any four wheel drive vehicle. These features allow drivers**
    **to apply mixing between steering, throttle and channel 3.**
    FEATURES: FASST (Futaba Advanced Spread Spectrum Technology) sends twice as
    much information to the receiver at eight times the resolution of
    standard systems for unsurpassed control and smooth servo travel
    2.4GHz circuitry is wired directly into transmitter eliminating
    separate plug-in modules
    "Auto Detect" instantly determines whether HRS or PPM mode is active
    in the receiver (R603FS only)
    Special ID code prevents signal interruption by rejecting unwanted
    signals
    Brake mixing for large cars
    Anti-skid braking system (ABS)
    Throttle Acceleration (ACC) minimizes time lag before clutch and
    brakes are connected in gasoline engine cars
    Steering speed adjusts steering servo operating speed
    Racing timer
    Function select lever function
    In addition to great performance in R/C car and truck applications,
    this system is also ideally suited to the rigors of boat racing
    10 Model Memory
    One year limited warranty through manufacturer
    INCLUDES: 2.4GHz FASST Futaba 3-Channel 3PMX transmitter
    2.4GHz FASST Futaba R603FF 3-Channel Receiver (FUTL7631)
    ON/OFF switch harness
    Instruction manual
    Futaba 2PL 2Ch 2.4GHz Sport FHSS Tx/R603GF Rx No Servos 109.99
    FEATURES: FHSS (Frequency Hopping Spread Spectrum) eliminates frequency pins
    and signal interference-pushbutton transmitter/receiver linking
    with no binding plugs
    R603GF receiver has a flexible coaxial antenna that is easy to
    position inside model for ideal reception
    One-button programming for fast and easy menu access
    EEPROM memory stores and selects preset programming for up to ten
    different models
    One trim switch allows setting and adjusting trims without returning
    to the menu
    Steering dual rate strategically located on the grip close to the
    trigger offers more mid-range control, crucial when cars are going
    into corners
    Steering/Throttle End Point Adjustment (EPA) limits servo travel for
    more control and to prevent servo damage
    ABS braking initiates ON and OFF pulsing for less skidding and can be
    set for slow, mid, or fast pulsing
    One year limited warranty through manufacturer beginning at date of
    purchase
    INCLUDES: Futaba 2PL 2.4GHz Transmitter
    R603GF Receiver, FUTL7615
    On/Off Switch and instruction manual
    DX3.0 DSM 3CH Radio with 3Ch Rx - No Servos by Spektrum 129.99
    Key Features
    Built-in 2.4GHz DSM technology
    3-channel DSM receiver (1)
    Easy-to-read LCD graphics display
    4-model memory
    3-Character Model Naming
    Electronic digital trim levers for throttle and steering
    Throttle deadband
    Normal and Fast modes
    Servo endpoint adjustments
    Sub Trims
    Servo Reversing
    Steering Dual Rate
    Lap Timer
    2 SV 27's and Vac-U-Pickle UL-1 Power
  • Steven Vaccaro
    • 8718
    Nice job! so which one you using?
    Steven Vaccaro
    • badag98
      • 190
      I bought a Tactic TTX240 and it made a huge difference compared to the stock radio. No more stalls in the middle of the lake or the boat just taking off on its own!
      By far the best upgrade i have made to my setup so far, and I have done quite a bit. Actually bought a Rio EP just to get a second set up for my kids boat.
      • Jeff Wohlt
        • Jan 2008
        • 2716
        The airtronics sure looks nice and with the memory and screen it gives you much better info. I did not know they had that one.
        I ike the hobbcity one for $22.00. It also has cruise control when you least expect it ....LOL
        www.rcraceboat.com
        [email protected]
        • wizard122
          • 483
          I use the Futaba but the new Airtronics for the money looks real good. I have used their radios in R/C cars and never had any problems and it has all the whistles and bells.
          • Diesel6401
            Memento Vivere
            • 4204
            I may have to switch to that airtronics mx3. Same price as the tactic sounds good to me. Only reason I use the tactic is because it came with the rio ep and my ul-1 and its so light on 4aa. I do like it though. Just too basic sometimes. Good research buddy!
            - Diesel's Youtube
            - Diesel's Fleet
            • Stickman
              • Feb 2010
              • 5
              Is it really that bad? I was thinking of getting it. Must be better than the stock AM right? Maybe I'll have to save my pennies for something better. :)
              • Jeff Wohlt
                • Jan 2008
                • 2716
                Not sure. I was going to get one for the Stampede for the boy just to test it and see what happens. I only heard results but not sure you can trust that.
                www.rcraceboat.com
                [email protected]
                • wizard122
                  • 483
                  The cheap 2.4 radios from HK are just that cheap they don't have any range and the RX don't always work right out of the box be carefull
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    The nicest part about the Tactic is each additional receiver is only $25. All the other systems listed seem to have additional rx's a lot more than that. 4 addiotional rx's for $100 is kinda nice.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • vasy
                      • Dec 2009
                      • 333
                      Has anyone tried this module: http://www.r2hobbies.com/eng/proddet...prod=rcps21216
                      Seems like an interesting upgrade for older modular Futaba Fm radios.
                      Any thoughts?
                      • wizard122
                        • 483
                        Be careful of this stuff It's very low end I know some one with a park flier who bought a corona RX and had nothing but problems
                        • wizard122
                          • 483
                          The thing I love most about my Futaba and Ko Propo radios is I have multi model memory every boat or car I own has to be set up different I am not just talking trim but servo end point, throttle curve, servo balance I think these are great things to have when setting up a model so I select the model and every thing is just where it needs to be plus I have never had a failure with ether one of them never.
                          • ray schrauwen
                            • 9471
                            I own this: http://www.himodel.com/radios/2.4Ghz..._Set_N-4Q.html
                            Very similar to Airtronics 3Ch, SAME as the Venom 3ch 2.4G..., $65 + shipping. Nice, $29 rx's...
                            • mappo
                              • Feb 2010
                              • 488
                              Stick with the Futaba or Airtronics models, great programability and good range,I run the Airtronice so i am partial to it. plus $20 - 25 off the price of both radios.with tower coupons .if you want cheap? stick with Tactic not a bad radio.
                              Do you know what the biggest problem with the world is?
                              That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
