hello all, trying one of my first scratch builds. I fell in love with the style of the mystic hull, and decided to build a small one after seeing several of the other small 16 inch mystics built here.
Well, I am not impressed so far. the bottom is not as sharp as I thought it would turn out. I tried to use a female mold and I do not think I have enough vacuum to pull it into the sharp corners. The hatch plug also needs to be trimmed down as it is a bit tight.
Anyways, pictures attached of my first attempt. the nose will be filled with two part expanding foam, the bottom will be reinforced with epoxy/glass/kevlar. Motor, I am looking at the Turnigy 2836 shown. Not looking for speed demon, something that will run below 300 mph!
Brian
Brian
