My new SV27 46.3 mph
  • wizard122
    • 483
    Just put a new Ammo 2300 in my SV got her up to 46.3 mph it was awsome.
    2 SV 27's and Vac-U-Pickle UL-1 Power
  • damfurst
    • 261
    Looks cool running just barely out of the water!!
    • Karfrik
      • Jun 2009
      • 1177
      Tell us more about your setup...!! Lipo size? stock esc? stock hardware? prop size?............Thanks,Albert
      • bigwaveohs
        • May 2009
        • 535
        http://www.youtube.com/watch?v=GoV48nAynQc
        What batteries/prop are you running?
        I let the dogs out...
        • rchippie
          • Jan 2010
          • 567
          Your boat looks good .
          • wizard122
            • 483
            Hi I am using Turnigy 5000 40C
            Grim Racer 40X52/3
            tabs even
            strut 1 deg pos
            Rudder kicked back 2 deg
            COG 7.5
            Ammo 2300
            Stock esc
            Scuffed bottom Red Scotch Brite
            • z400
              • 1311
              Your rudder needs to be tucked forwards, not backwards.
              Z
              KBB34" Mono - Fast
              ToySport Triton- Not as fast
              • wizard122
                • 483
                I tried it both ways and it handled better kicked back a little?
                • z400
                  • 1311
                  You sure its staight?
                  Plenty of "best results" with the rudder tucked forwards.
                  Never heard of anyone having any luck running it outwards
                  Z
                  KBB34" Mono - Fast
                  • Rumdog
                    • 6453
                    It is only 2 degrees. Depends on how the hull is running. Outward kick can help keep it planted in the turns. Too much thogh and it will create too much lift.
                    • wizard122
                      • 483
                      Yea it's only 2 seems to be running great
                      • detox
                        • Jun 2008
                        • 2318
                        Hull looked slightly loose on water. Move COG slightly more forward and/or bend trim tabs down slightly more.
                        • Lasse Baardseth
                          • 69
                          My stock SV27 got up to 62,7 mph on 8s
                          It did not last long, but great fun!
                          • z400
                            • 1311
                            Thats nothing to brag brag about.
                            Z
                            KBB34" Mono - Fast
                            • Lasse Baardseth
                              • 69
                              Just something we found out after too many beers, not ment as brag.
