Cativation
  • BHChieftain
    Fast Electric Addict
    • 1969
    Cativation
    Hi,
    I upgraded the (broken) stock prop with a 440/3, sharpened and balanced. I like the speed the boat gets with it, but it does cavitate a little before it gets on plane. I'm a little worried the RPM limiter will kick in at some point, as my son will take the turns pretty slow which drops it out of plane frequently.
    Do you think adjusting the shaft angle would make any difference, or should I just move to X642?
    -Chief
    Sorry about the thread misspelling-- I can't seem to edit it (moderator, help?)
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    I had X642 on my sold Formula and it was great so yes, try that prop.
    Canada
    • egneg
      • Feb 2008
      • 4670
      If you could lower the strut a bit (1/16 - 1/8) keeping the angle the same it may help as well.
      IMPBA 20481S D-12
      • LiPo Power
        • May 2009
        • 3186
        ...any chance for pictures of your set up from the back and side?
        Canada
        • BHChieftain
          • 1969
          Here's the setup,
          -Chief
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7119
            Does the one I sold you (formerly Robert's) happen to cavitate on your three blade prop? it has a much more adjustable strut... The stock strut is miserably limited in its adjustments. Personally, I would probably just use the x642 which had NO cavitation problems.
            "Look good doin' it"
            See the fleet
            • BHChieftain
              • 1969
              I'll swap the props between the 2 boats and muck around with the adjustments on Robert's since there are more degrees of freedom on that one...
              -Chief
              • LiPo Power
                • May 2009
                • 3186
                ... Just like Jesse said, X642 will have no cavitation problems no matter what the angle is. If I remember properly I had the same problem trying Ul-1 prop and decided to swich back to X642. That prop made my Formula even more stable with great speed of arround 37MPH on stock setup and still great controll of the boat....
                Cheers
                Robert
                Canada
                • BHChieftain
                  • 1969
                  Cheers
                  Robert
                  Hi,
                  Just finished 2 runs today with the X642. It's much better than the 440/3, no cavitation at all...
                  Thanks,
                  -Chief
                  • LiPo Power
                    • May 2009
                    • 3186
                    Originally posted by BHChieftain
                    Hi,
                    Thanks,
                    -Chief
                    Way to go!!!!
                    Canada
