hey guys,i just got my fastech and wanted to here some helpful ideas of doin some stock tweakin to make the boat perform,handle,and maybe get a little more speed out of it?
with that motor I doubt you would EVER notice the difference. That motor sips on the batts, very low amperage draw. I am super duper happy with my 20C $25 Rhino batts from hobbyking.
I would use two 4S in parallel, you need the weight since you are using lipos - boat was designed for NIMHs and 1 4S is about same weight as 1 6cell pack. I ALWAYS modify the leads coming out of the ESC to one - either deans or 5.5 mm plugs to the batteries. This way if you want to run 1 or 2 you just plug it in or use a Y adapter, respectively.
Mine were 4800 - 5000 mah, not less than 4500mah though.
