Go Back   Offshore Electrics Forums > AquaCraft RTR Questions & Answers Board > AquaCraft Mini Rio Q & A
Reply
Thread Tools Display Modes
brushless mini rio hardware options
Old 11-09-2009, 05:39 PM
thegreat1 thegreat1 is offline
Default brushless mini rio hardware options
hey guys i just wanted to let you know that i threw the mini strut and rudder from ose, well let me tell ya what a great combo. i love having a way to tune my boat. i also rearranged the layout of the inside of the thing to make so more room. boat handles great. my setup is a turnigy watercooled 2845 3600 motor, thunderbird 54 esc, .098 flex, and a reef racer prop. if i am able to i will get some vids and i will post some pics later tonight.
the only reason i posted this is for some more novice boaters that could use a little guidence on the boat in particular. if anybody alse has other setups hardware wise post here.
here are some pics
Old 11-11-2009, 10:16 AM
Default here are some pics
this gear works like a freaking charm!! i recommend it to anyone modding a mini rio.
Old 11-19-2009, 01:07 AM
p.swiggs p.swiggs is offline
looks quite nice i'd have to say
Old 01-09-2010, 02:39 PM
corey24 corey24 is offline
love the look of it
Old 01-23-2010, 06:43 AM
koontek koontek is offline
Nice boat! how fast do you think it goes? Can you post some pictures of the inside?
Old 01-23-2010, 11:19 AM
i'd say it is the 28-32 mph range right now it is torn apart (swaping motors) the new hardware makes this boat run so good.
Old 03-25-2010, 12:34 AM
tiqueman's Avatar
tiqueman tiqueman is offline
Fast Electric Adict!
Any updates? Vids? Pics?
Ive got the hrdwr on mine, but no electronics yet. I removed everything from the inside, all abs plates, motor mount etc. Just waitin on parts to start buillding it back.
Old 04-27-2010, 10:44 PM
Diegoboy's Avatar
Diegoboy Diegoboy is offline
Moderator
I had to do a double take. That last pic looked like a micro stinger. I was excited to get one from the store too...
__________________
BBY CF Zephyer-27 H&M Viper Turbine Baby Freya Twin Cat H&M Micro Kat Tunnel Offshore Warrior Rigged Confusion Rigged Insanity Micro eflight cat Climate Matrix Team Lindenau Smiths cat Pro Boat Stiletto (when it comes out) THE Original Renegade rigger (retired)
Old 05-02-2010, 09:45 PM
Jesse J's Avatar
Jesse J Jesse J is offline
Nice, I threw on a Solinger mini rudder and just added a brass bushing to my stock stinger... did upgrade to .098" flex and slapped on an X432 prop - Here is a vid from today... don't think I need a styly stinger (other than to look super sweet). I took some pics of the innards and hinney to post. Oh and I sillyconed the hatch so it is water PAROOF!!
__________________
"cheap, fast, reliable...choose any two"
See the fleet
Old 05-02-2010, 10:02 PM
Jesse J's Avatar
My mods were more inspired by damage resulting from it falling and landing on its rear - all busted AND transom cracked... I also ripped out the abs from the inside and then CA'd everything back.... the motor mount ain't comin out without a fight.
__________________
See the fleet
Old 05-02-2010, 10:07 PM
tiqueman's Avatar
I used a flat edge blade that goes into an exacto knife.. almost like a mini sharp putty scraper to remove all the guts outta mine. Worked wonderfully. Just run the blade the correct side up so it doesnt dig into the hull.
Old 07-30-2010, 11:32 AM
larryrose11 larryrose11 is offline
Hello All,
I inherited a Mini Rio from my brother. I then proceed to do some extensive mods.
- tore out the stuffing tube,
- upgraded to an OSE .095 flex drive.
- glass reienforced the inside.
- 3600KV motor from eBay kinda heavy
- a 30 A ESC, water cooled, also from eBay
- same drive hardware that TheGreat1 used, the micro strut and rudder from OSE
- Octura y534 Plastic prop
- 2S 1000 mah, 30C Turnagy Lipo
It runs wonderfully, about 30 mph
Im gonna try a 3S, 1200 mah, 45C Thunder Power battery later on today.
Pics / vid to come.
Old 08-02-2010, 06:50 AM
OK,
I shot some video
Here ya go, running on the Hurom River, S.E. Michigan
It goes pretty fast for a 14 inch boat, about 30 MPH
Oh, I ended up not getting the 3S battery, so in the vid its running 2S, 30C, 1000 mAh battery
Video Link
Old 08-11-2010, 04:02 AM
Brushless01 Brushless01 is offline
Can you please get pictures of your boat larryrose11
__________________
Aquacaft Rio 51 stock with Tuned pipe, Aquacraft supervee 27 Ammo 2300 Ul-1 esc, Aqucacraft mini rio brushless, Delta Force 29 Knock off Supervee motor and esc, Hpi Baja 5b ss, Hobao Hyper st.
Old 08-12-2010, 12:26 PM
Sure. Ill take shots when Im done making it purdy.
My back end looks just like TheGreat1
Old 08-24-2010, 07:56 AM
OK, after a bit of a hiatus, I have finally got some shots together, in all the ugly details.
You can see more detail in the shots than in life it seems!
You can see that I used the stock motor mount, and I'm glad I did, because the balance point for this hull seems to be about the middle of the front access hole.
The yellow in the bottom of the hull is the 3 layers of 3/4 of fiberglass.
you can also see the cover I made for the coupler, because it is tight in there, and I want rotations parts covered. Im trying out some new hatch gasket which I use with hatch tape too, but Im not sure it works any better than just the hatch tape. I also replaced the tubing alon the side, because I wanted something tougher.
next huge shot:
more:
It runs great in rough chop too.
Here is a vid of it in chop, running on 2 cells.
http://www.youtube.com/watch?v=3Lz6FH4jO3E
Old 08-27-2010, 12:44 PM
I just put a 3s pack in, IT FLEW!!
Then in short order, my coupler, which was a stock unit I bored out to fit my motor, failed. I lost the prop and shaft. Lucky for me, I was in shallow water at the time, so I retrieved the boat.
Order placed, should have new parts soon.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2002, 2003, 2004, 2005, 2006, 2007,2008,2009 All rights reserved!
| Home | Register | FAQ | Members List | Calendar | Today's Posts | Search | New Posts |
