Props for sale
  • TRUCKPULL
    • 2971
    Props for sale
    PROPS FOR SALE
    The pic's below are from the thread I started last spring.
    I have 20 props for sale.
    Example of listing: X648 (46.6mm) B/S DT BC
    If there is a number in the () the prop is cut down to this Diameter
    B/S = Balanced and Sharpened
    DT = Tetounged
    BC = Back Cut
    Tip = a little extra Cup on the trailing edge
    Shipping is $6.00 per order unless you buy them all, then I will pay the shipping.
    2- X637 Raw -------------------$12.00
    5- X637 B/S DT----------------$20.00
    6- X637 B/S DT ---------------$20.00
    20- 1740 Raw---------------------$9.00
    21- 1740 Raw---------------------$9.00
    40- K51 Carbon prop ----------------$5.00
    Post here the props you would like.
    PM me your prop #'s
    I will then send you my PayPal info
    Larry
    Current NAMBA- P Mono -1 Mile Race Record holder
    Current NAMBA- P Sport -1 Mile Race Record holder
  • Ub Hauled
    • Aug 2007
    • 3031
    Hi Larry,
    I'll take the following...
    22- V940/3 B/S ---------------$20.00
    30- V947/3 Raw------------------$12.00
    • gyrotron
      • Jul 2012
      • 481
      Hello Truck,
      Of this lot of props, which one would you recommend for a PB Blackjack 29 running a 1800 Kv motor on 6s? I have heard than above 1600 kv a smaller prop should be used on a 6S count. I am currently using an x440 /3 and was looking for another prop.
      Thx
      • TRUCKPULL
        • 2971
        Originally posted by gyrotron
        Hello Truck,
        Thx
        The
        1800kv on 6s is about 37,800 RPM
        Are you running SAW's??
        Every hull has a prop diamiter that it likes best. From their you ajust pitch and cup.
        On a cat I would say to use about 30,000 to 32,000 RPM
        On 6s this would be about 1450 to 1600 KV at 21 volts under load.
        For the above reasons I can not say for sure what prop would be best for you.
        Larry
        • SpeedFreak_86
          • Jun 2011
          • 182
          Would any of those three blade props work well on a spartan with a 1600kv 4082 on 6s?
          Slow and steady isn't my pace
          • TRUCKPULL
            • 2971
            I am sorry. I don't know the Spartan Hull.
            Larry
            • SpeedFreak_86
              • Jun 2011
              • 182
              It's a 40 in v hull with a 3/16 prop shaft, rite now I'm running a 42mm x52mm
              • TRUCKPULL
                • 2971
                A 1600kv 4082 on 6s In a 40" V hull should have a larger prop then a 42mm Diamiter.
                My P Mono 33" on 4S2P runs a 48mm Dia. 3 blade Prop.
                Ask this question on the question and answer fourm;
                What prop for a 40" V hull running a 1600kv 4082 on 6s??
                also add if it is 2P or 1P.
                Larry
                • gyrotron
                  • Jul 2012
                  • 481
                  Truckpull.
                  I'll take the x438 prop #12
                  Thank you
                  • don ferrette
                    • 1093
                    32- X648 (47.4) B/S DT----------$20.00
                    33- X648 (47.6) B/S DT----------$20.00
                    If these are still available I will take both. Please p/m me with details.
                    - IMPBA Hall of Fame -
                    • TRUCKPULL
                      • 2971
                      Truckpull.
                      Thank you
                      PM sent
                      Larry
                      • TRUCKPULL
                        • 2971
                        PM sent
                        Larry
                        • gyrotron
                          • Jul 2012
                          • 481
                          Originally posted by TRUCKPULL
                          PM sent
                          Larry
                          TRUCKPULL,
                          Payment has been sent.
                          • Meniscus
                            Refuse the box exists!
                            • Jul 2008
                            • 3225
                            Larry, you have a 2137/3 pictured, but not listed for sale. Three questions:
                            1. Is it for sale?
                            2. What's the history on this prop, meaning did you sharpen and balance?
                            3. Have you modified this prop in any way or is it the original profile?
                            • TRUCKPULL
                              • 2971
                              1. Is it for sale?
                              Props that are pictured but not listed are already sold.
                              Larry
