Sprintcat build
  • sailr
    • Nov 2007
    • 6927
    Sprintcat build
    Where did my build go that was posted this morning?
    Mini Cat Racing USA
    www.minicatracingusa.com
  • sailr
    • Nov 2007
    • 6927
    Jeeez, guess I'll have to start over. OSE ate my thread!
    Mini Cat Racing USA
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7116
      recon that's not as bad as eating your boat
      "Look good doin' it"
      See the fleet
      • sailr
        • Nov 2007
        • 6927
        hehe. you are correct sir!
        Mini Cat Racing USA
        • Rumdog
          • 6453
          let's see it! I'm re-doing mine right now too!
          • sailr
            • Nov 2007
            • 6927
            Okay, let's try this again! Ha!
            The first thing I did was to cut out the wooden rails so I could get my battery packs into the sponsons.
            Added Carbon Fiber from the front bulkhead to the transom.
            Next, trial fitted the motor, a Feigao 580 10L and Williams Mount.
            Note the "classic" hatch for the Sprintcat turned around backwards! Makes for a much sleeker appearance.
            Mini Cat Racing USA
            • DISAR
              • Aug 2007
              • 1072
              Cool, what voltage? 6s1p, 6s2p...
              It is quite difficult to place a 6s lipo 5000 mah in the sponsons, I cut also some part of the deck edges
              Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
              http://www.rcfastboats.com/
              • sailr
                • Nov 2007
                • 6927
                6S2P. Yes, you can't squeeze 5000's into the sponsons. I have some 4350's that will fit. A friend of mine is running two 3S in series and then paralleled with another set. (3S2S2P?)
                I didn't think of cutting the lip slightly! I'll check that out. Otherwise I was going to have to order some more 4350 batts! My original plan was to put the batts behind the motor but no way to achieve the COG that way.
                Mini Cat Racing USA
                • Fluid
                  Fast and Furious
                  • 8012
                  I run 6S2P/4500s behind the motor and the boat runs great.
                  • rchippie
                    • Jan 2010
                    • 567
                    Looks good so far jim how long untill your finished ?. I got my hull the other day . I also need to cut the stock wood rails out to do what randy did. But i dont feel comfortable doing that with my very limited knowledge of boats . Im thinking about sending it to randy for him to convert instead .
                    • RaceMechaniX
                      • Sep 2007
                      • 2821
                      From the side view the cowl looks half way decent.
                      Jay,
                      Out of curiousity that tailgate looks familiar, an "indyram" or a Dakota?
                      Tyler Garrard
                      NAMBA 639/IMPBA 20525
                      T-Hydro @ 142.94mph former WR
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        Jay...full boat there! :) Is that a fan at the end of the motor blowing on it and the ESC?
                        www.rcraceboat.com
                        [email protected]
                        • Rumdog
                          • 6453
                          Lookin good. Here's a pic of mine with the 1527 and Zicha mount...
                          • Fluid
                            Fast and Furious
                            • 8012
                            The fan blows into the motor and across the ESC. Helps with cooling since the hull volume is large. Plenty of room for everything necessary and leaves the sponsons for the most important function - flotation! . There is no advantage to running the packs in the sponsons, this boat handles great as you see it and has made official SAW passes in the 80s. While it seems intuitive that a low CG should help handling, in reality this is not the case in the cats I've played with. In fact ten years ago several club members tried it both ways with Key West cats and found that placing the packs on the tunnel gave superior handling on a tight (very tight!) course. I put them where it is easiest, handling is not the issue.
                            Dakota R/T tailgate.
                            • bustitup
                              • Aug 2008
                              • 3071
                              looking good sailr...what class will you run this boat in?....I may bring mine to race with you...mine has a 580 9l on 6s and 8s
                              I love the backwards classic hatch....it will look even better if you paint it right
                              just a note: man you know a guy is doing well when he has a piece of carbon fiber the size of a large table cloth
