What To Use To Clean Boat After Burn ESC???
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    It did work for me right after Castle Creations Hydra-120 went on fire under the hood of my BJ-26. Ohh man she was black inside, never mind the smell. It was so strong many other guys from the race team could not believe how bed it was. Went home and was trying so many cleaners but no one of them was able to get rid of burn stains and the smell. Last one to try was..... See the picture. It works like a charm. On the background you see yellow huch that was very dark from another hydra-120 fire and when I got the boat it came with this huch still very dark from ESC fire and smoke. Now it is clean and yellow again!!!Try it!
    Canada
  • Raydee
    • May 2007
    • 1603
    WOW that looked like it worked great!
    Did it take some of the smell out of the hull too? I had one cuda 125 burn on me a while back and the smell never went away. The esc litterally looked like a piece of charcoal and the whole inside of the hull looked like your cowl.
    Team Liquid Dash
      • 9488
      That's awesome!
      Looks like an add for Easy-Off
      you should be getting paid!
      • Fluid
        Fast and Furious
        • 8012
        I would be very careful using EASY-OFF HD in an FE boat. This is a caustic product and the maker warns about using it on stainless steel or aluminum - it can pit the metal. The maker warns not to use it around Teflon, but is unclear about its effects on plastics. After use, EASY-OFF says the treated surfaces should be "rinsed in a vinegar and water solution" to neutralize the caustic residue.
        I've had excellent success with denatured alcohol in removing stains and smell from a ESC fire. Safer than EASY-OFF, it seems to work about as well. If you are using EASY-OFF just be aware that there could be problems.
        • egneg
          • Feb 2008
          • 4670
          Easy-off is basically sodium hydroxide and needs to be heated to 160 degrees to reach maximum effectiveness (that is why an oven is supposed to be warm first). It is also used in drain/toilet cleaning products. It will react with aluminum as it is used to clean masks in the auto headlight making process as the plastic headlights use a coating of vaporized aluminum on the reflectors. It will not cause any problems with steel, plastic, etc. I am thinking that what is being cleaned is what is left of the burnt aluminum on the various boat parts from the cooling plate/tubes.
          P.S. It will also remove the galvanizing on steel as it is a strong base (also known as lye) and galvanizing is achieved with an acid process.
          IMPBA 20481S D-12
            • 9488
            Looks like a great Idea!
            • LiPo Power
              • May 2009
              • 3186
              Well, after using it on BJ I can tell you nothing got damaged. I did rinse with worm water after and it took most of the smell away.
              Canada
              • drwayne
                • May 2008
                • 2981
                Ive located an equivalent to EasyOff down under in Au, but where in hell could I find 'worm' water ?
                W
                • egneg
                  • Feb 2008
                  • 4670
                  W
                  It is in the gourmet section of the grocery store.
                  IMPBA 20481S D-12
                  • drwayne
                    • May 2008
                    • 2981
                    Ahhh
                    online store has it listed between L'escargot and leg le' kermit.
                    • LiPo Power
                      • May 2009
                      • 3186
                      W
                      Worm water you can find at home from your sink
                      Canada
                      • sailr
                        • Nov 2007
                        • 6927
                        eeewwww, now you got worms in your boat from the worm water? icky! We all know you meant WARM water.
                        Mini Cat Racing USA
                        www.minicatracingusa.com
                        • FRED
                          • Jul 2007
                          • 233
                          Clean up after esc burn
                          Down under found the answer.
                          • Apples1
                            • Dec 2007
                            • 406
                            Eucalyptus Wool Wash, cleans all trace and smell for me.
                            Sounds bad, but leaves the boats soft and Cuddley.
                            returning to boats after a big break
                            • Bigmaxy
                              • 16
                              Big for the non caustic oven cleaner on for 30mins followed by Chux Magic eraser. Good as new again..
