HK Osprey/Delta 39' copy
  • TwzteD
    • May 2010
    • 91
    recently bought the "1075mm" or 41'' delta copy from hk, http://hobbyking.com/hobbyking/store...9_Plug-n-Drive
    was wondering what would be the best setup for the boat, im gonna reinforce it like many do with the copy's, but what im looking for is a quick and reliable setup, the esc im assuming needs to go and possibly even the motor what would some recommendations be? id like high 40s low 50s if possible, like what feigao motors and esc would be a good combo, trying not to spend too much more considering i spend 425 for it already and ill still be buying battery's, anyone have any pics of a real delta 41 setup or any good ideas, thanks in advance.
    • 9488
    The motor that boat comes with is very much like a Castle/Neu 1515
    you should see 40's on 4s
    • TwzteD
      • May 2010
      • 91
      few ppl over at hk are thinking the motors is this http://model-hobbies.com/4074-Leopar...s-LB-4074-120/ sounds like a pretty decent motor then.
      • Make-a-Wake
        FE Rules!
        • 5557
        I'd just leave the stock motor in there and try it on 4s........and 5s...........new esc of course.
        • Jeff Wohlt
          • Jan 2008
          • 2716
          That does come with the leopard motor. Can run on 5S but I would try 6s :)
          www.rcraceboat.com
          [email protected]
          • TwzteD
            • May 2010
            • 91
            ok so about a new esc, is the Turnigy Marine 180A good enough or would you recommend something else ?
              • 9488
              the stock esc could work well?
              but the Turningy 180 would be very nice in this hull
              • TwzteD
                • May 2010
                • 91
                Do you think this motor is capable of 6s?
                  • 9488
                  It is, but I would not risk it until you try 5s in this big hull!
                  • TwzteD
                    • May 2010
                    • 91
                    anybody else order one of these or have one? or the real one
                      • 9488
                      you could be the first
                      • j.m.
                        • Jul 2008
                        • 838
                        I wish the hardware was available separate, it looks really nice...
                        • TwzteD
                          • May 2010
                          • 91
                          got it yesterday nice boat awesome hardware but leaks like crazy needs to be sealed! decals peal off easily it does indeed come with the lepord motor and a seaking 120 esc. ill get pics up asap
                          • TwzteD
                            • May 2010
                            • 91
                            • sailr
                              • Nov 2007
                              • 6927
                              I, for one, am very interested in how that Leopard motor performs and holds up. They make a lot of claims for it. It will be nice to know if they are true! I think Steven here at OSE is going to be carrying them.
                              Mini Cat Racing USA
                              www.minicatracingusa.com
