Neu 1515 2.5d vs medusa 3680 1600kv
  • Punisher 67
    Ignore list member #67
    • May 2008
    • 1480
    I bench tested both motors since they were the topic of a heated discussion a while back . the 1515 and 3680 I figured where close in power output at similar Kv's
    The battery pack was a 4cell 5000mah lipo pack and the load was a 8-6 aircraft prop
    WHO WANTS TO SEE THE RESULTS
  • Doby
    KANADA RULES!
    • 7280
    I do! I do!!!!!
    Grand River Marine Modellers
    • Punisher 67
      • May 2008
      • 1480
      Neu 1515 2.5d 1700kv
      NEU 1515 2.5D 1700KV
      Actual Kv = 1693.7
      No load amps 1.75
      Timing 11.25*
      Rpm no load = 28080
      Rpm load = 21186
      Rpm loss = 6894
      High amps = 90.91
      High watts = 1342
      Temp start = 62.9
      Temp finish = 114.0
      Eagle tree graphs below
      • Punisher 67
        • May 2008
        • 1480
        Medusa 3680 1600kv
        MEDUSA 3680 1600KV
        Actual Kv = 1690.8
        No load amps = 3.5
        Timing 11.25*
        Rpm no load = 27880
        Rpm load = 21008
        Rpm loss = 6872
        High amps = 89.16
        High watts = 1316
        Temp start = 62.9
        Temp finish = 101.0
        • calcagno45
          • Mar 2008
          • 1006
          Hmm, Looks pretty close. Medusa underrated its KV.
          I would love to see these 2 in an endurance test....
          • Brod
            • May 2009
            • 196
            temps are interesting,but to be fair the medusa is a heavier motor,plus those fins are running the 'right' way for prop blast.
            I have a medusa 1600kv in my hand now ready to fit in a 33" mono.
            It would be good to see the test with same kv Fiegoa XL motor.
            thanks for posting Peter..
            Brod..
            Slow gets boring fast.
            • Punisher 67
              • May 2008
              • 1480
              I have to say even on 4 cells both motors are scary , the max safe rpm for the prop was exeeded by about 3000rpm , if I was to run these on 6cells I don't even want to be in the same room...............
                • 9488
                This is great!
                what's interesting to me is the constant power ratings, the Medusa edged out over the Nue and also the Batts were a tad low on the Medusa vs the Nue test
                very close numbers, and the Medusa is how much cheaper?
                I would love to see a XL motor ran on this test to see how it does..
                Great Job Man!
                • Brod
                  • May 2009
                  • 196
                  He,he,we used to run a 150mph plane on a Neu 1907 1.5y on 6S with a 8-8 prop,it had to be nitro prop.It had to be catupulted of a launcher,but once the high pitch bit,WOW!
                  Power was awesome.
                  Brod...
                  • Ub Hauled
                    • Aug 2007
                    • 3031
                    Great info Peter!
                    both are very, very similar except when it comes to the price tag...
                    one thing though... lab racing is VERY different then real racing, before making
                    rash assumptions one should have seen/used them both in action.
                    IMO of course.
                    • crabstick
                      • Jul 2008
                      • 954
                      what is the price comparison ?
                      Matt.
                      FE, Nitro and Gas racing in Auckland
                      www.rcboats.co.nz
                      • Raydee
                        • May 2007
                        • 1603
                        Neu=$210
                        Medusa=$125
                        I am still going with the Neu
                        My bud is going to run the 1600 Medusa in his Whiplash and I am going to run the Neu both on 4s1p Hyperion 5500 35c cells. I am hoping they will be very comparable.
                        Team Liquid Dash
                        • bustitup
                          • Aug 2008
                          • 3071
                          Neu is $245
                          Medusa is $145
                          • crabstick
                            • Jul 2008
                            • 954
                            Cheers ..... *runs off to look at medusa site
                            Matt.
                            www.rcboats.co.nz
                            • calcagno45
                              • Mar 2008
                              • 1006
                              Good luck with those bearings over time...
