Here goes again. heading into the cold Michigan Fall/Winter so I am heading down to the basement to start a new build. I have a new child coming in the next couple weeks so this will be a slow yet very detailed build. I received the hull a couple months ago and just started this evening on mounting the struts. I have all parts except motors at this point. Each post I will show pics of progress.
H&M Maritimo
Tags: None
I have mounted the 2 sv struts that have been modified with lead bushings. They seem very smooth and couldnt beat the price. I used the masking tape to mark holes and they came out just as i wanted. Next to come is the rudder system.Attached Files -
Getting a chunk of spare time today I modified dual rudder system, instead of bending to shape i cut just what i needed and still need a little machining to do on them but they work perfect. I am also going to trim about 3/4-1" off rudders. Holes are in boat and as you can see with crearance. Im only mounting them once after paint.Comment
I have always wondered why RC rudders are squared off at the back ends. Would it not help if they had a sharp exit as well as entry into the water?Comment
to see which one has the most drag. I think the wedge allows the water to come straight off the end of the rudder, while a sharp edge may pull the water from both ends together causing a vacumm efect.I Dont Know what Im saying. lol
Island Boys Fast Electric HawaiiComment
It wasnt alot of trouble to go with dual's at this point. I am looking for handling all the way. If need be I can mount just one in central location and well, it looks cool as hell in my own opinion.Comment
Or something like that. still looked cool
On a twin cat you want the stingers as close to the tunnel and as far down as possible. They will cavatate like crazy if you dont get them down. ( especially at high speed.Comment
good point but if you look at the inside hull pics its as close as possible using back plates. I know speedmaster stingers would have been larger since i used them before and with the weight of twin motors . well we'll see.Comment
The hull was indeed rough and needs finished but its fun to do. I put all the holes in first for hardware since I dont have patience once its painted. will post pics of that soon.Comment
