I have built 2 JAE that have ...
Epoxy Glass tub
Motor mount
stuffing box
strut
rudder
cowl for motor hatch
Servo extension installed in bulkhead between motor and radio compartments
Epoxy sealed sponsons
carbon booms.187" drive-line
boot for rudder linkage installed
aluminum boom clamps (simple collar with set screw)
carbon tube installed between transom and motor compartment to run water line through
1/16th" wood to sheet the bottom of the glass ski after painting.
the weight of everything above is 27.06oz
All you will need to do is sand prep paint (this is epoxy and it will have pin holes and require some fill and primer. this is normal for properly laid up epoxy), install your electronics , rudder linkage ,servo, motor,bolt on your preferred turn fin. 90%+ is done for you.
photos here
$200.00 + any shipping or paypal fees
Again the tub is epoxy glass and will need to be prepped and painted. The first one I built for myself can be seen as I run it here I have two others that I built for sale. This is built from the plans from Rod G. for the electric boat rather than the modified version that is sold for electric and nitro that one has the booms closer together. I did add a 3rd hatch to save on radio box tape.
Epoxy Glass tub
Motor mount
stuffing box
strut
rudder
photos here
