Attaching extra caps to Hydra 240
  • AntronX
    • Jul 2008
    • 333
    Instead of soldering this ETTI capacitor board to main power wires, I thought about doing it slightly different way. I soldered it directly to power FET board using four 16 gauge silicon wires per board. I decided to use this thin wire to reduce skin effect losses. I think the outcome is cleaner install and preserved usability of controller's battery wires that are already too short.
  • AntronX
    • Jul 2008
    • 333
    more pics
    • ApacheDude
      • Sep 2008
      • 83
      Just curious on why 4 wires? I would think 1 large or even two smaller ones would be sufficient.
      Boats:
      Proboat Apache 24
      Proboat Blackjack 26 Brushless
      • longballlumber
        • 3132
        Let us know how this works!!! packaging the 240 is already a PIA
        • AntronX
          • Jul 2008
          • 333
          This extra capacitor bank is definitely helping out. We ran it for few laps and temperature of original caps was noticeably less than before. The setup is Mean Machine cat with Neu 1521 1Y (1577Kv) on 6S LiPo (6Ah 25C) running X442 prop at 140 - 160 A full speed. The ripple was so bad that 5V regulator chip feeding Hydra's micro computer got so hot that it cracked a hole through the shrink wrap.
          I recommend extra caps to anyone running maxed out setups or just as cheap insurance for your ESC. Make sure to use 1 ohm 5W resistor to pre-charge all these caps before connecting batteries to avoid big spark.
          • longballlumber
            • 3132
            Can you explaine this in more detail? I am still a little new to this FE stuff.
            Can you use this extra etti cap board on the Hydra 120's too?
            Mike
            • AntronX
              • Jul 2008
              • 333
              More capacitors will cause bigger "pop" or spark when connecting second power connector between ESC and battery. Resistor reduces very high inrush current caused by charging capacitors, and eliminates that spark.
              Wiring diagram here: http://forums.offshoreelectrics.com/...5&postcount=68
              Extra caps can be used on any ESC, just make sure their voltage rating matches voltage rating of capacitors on your ESC.
