The Full FeCalc install program file
  • ReddyWatts
    • 1711
    Steven has uploaded for us the install exe file (5 meg in zipped format) for installing FeCalc on your computer.
    This program was designed to use with 2 pole motors.
    http://www.offshoreelectrics.com/dow.../FEPackage.zip
    This is an updated equipment file you can use in FeCalc.
    You can replace the text file in the fecalc directory with this one or add your equipment to it manually.
    Use a single tab when adding data and going to the next column in the equipment text file.
    ReddyWatts fleet photo
  • ReddyWatts
    • 1711
    If your current version of Fecalc is working, I do not recommend loading this one. Could cause a problem.
    • ReddyWatts
      • 1711
      Fix for Runtime error 380
      Quote:
      Originally Posted by mickvk
      After much struggling, I have a solution to this problem. It looks like during program startup, it looks for the last selections from the fecalc.txt file. If those have been modified, the program might throw that error. You can use another user account on the computer. Or you can go into the registry editor, HKCU\Software\VB and VBA Program Settings\FECalc\Startup and change various Value Data to 1. That worked for me. Phew, what a pain!
      Quote:
      Originally Posted by crabstick
      Deleting the whole key works also, this is good info!
      • ReddyWatts
        • 1711
        It installs the complete FeCalc program on your computer with the associated dll files and registry mods. There is a lite version of FeCalc (below) that does not need the associated files to work on some computers. You can download it into a directory on your pc and just run the program. If it asks for a dll file you have to install the complete program above.
        • ReddyWatts
          • 1711
          equipment file
          This my latest FeCalc equipment file.
          • ReddyWatts
            • 1711
            fecalc screen shots
            Yes to both questions. It is for estimating a boat setup when using 2-pole motors. It helps find a prop to start testing with. Always start with a prop smaller than is calculates and work up to your desired amps and watts. Less smoke more fun!
            • ReddyWatts
              • 1711
              I do not have those values.
              • mschaffer66
                • Jan 2010
                • 335
                Not that I'm questioning what you have done. Hell its a lot more "technical" than anything else I've saw for helping on setup, but what kind of calculations are going on behind the scenes? Basically why do we trust this thing?
                Please don't take that as a criticism. I was just wondering what kind of testing or whatever has been put into it. Hell for all I know you could be the god for FE and I'm questioning your calculator :)
                • ReddyWatts
                  • 1711
                  FeCalc used to be available on another web site, but recently went offline. I just supplied the program so others could continue to use it.
                  • mschaffer66
                    • Jan 2010
                    • 335
                    I'm just really curious where it gets the results from. Like you can just pick "cat" but no size associated. I wonder if there are certain assumptions in the program.
                    • ReddyWatts
                      • 1711
                      Yes, this program was written before we had the larger (over 34") FE hulls.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        Just an FYI- I can write windows shell programs in C#
                        Given some formula's I can write or re-write an associated application if needed.
                        FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
                        • domp444
                          • Jul 2009
                          • 846
                          Is this program available for mac?
                          If not, I can always run it in bootcamp :)
                          SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
                          • Chrisg81983
                            • Jul 2011
                            • 1556
                            Just curious Is there a newer updated version out something that will let you select a certain setup ex. Hull type, size, and motor type pack c rating, prop size and so on Thanks chris g
                            • ReddyWatts
                              • 1711
                              No, we have not been able to get in touch with the original programmer and have not found anyone that can update the program.
