Has anyone tried the HiModel 8s - 200 amp esc with 5 amp BEC?
HiModel 4s-8s 200 amp esc
ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Tags: None -
I used the 3-7s version in both my Cat and on my electric converted Revo truck. Great esc!! It never got hot, and kept on pushing. I just learned that water doesn't mix well, I didn't conformal coat it.
Well I see now they offer it in both 3-7s and 4-8s. I'd like to give it a shot. Looks like I need to build a new boat.My prop hasn't been wet in a while. -
I have used several, in both versions and they work good.. I always conformal coat them and add watercooling..Nothing like keeping you lipos warm and your prop wet!!Comment
txboatpilot, did you try it on 8s?ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
Used the Himodel 3-7s and works great but just received the 4-8s a week ago but our ponds are frozen now so will have to wait till spring. I use Plasti Coat to water proof the esc's and then shrinkwrap it seams to work good and no fear if water hits it. The cooling plate Steve sells fits the fets perfect (bottom row pics), I use Arcitic Silver Alumina Thermal Adhesive on the fets to cooling plate, its an epoxy so it will hold solid. The esc's on the top of each pic are the 3-7s the bottom are the 4-8s, wires for the motor are on the bottom with the fets on the 4-8s.
KenComment
Both esc'c are the exact same dimensions, just the cooling plate on the top of each pic is larger.Comment
Def worth a try for the price, if it blows up throw it in the trash at that price!Team Liquid DashComment
I have pushed a couple of mine on 6S and temped the caps at 140+ deg. and no failure... Just dont get to agressive with the props..
Reddy,
I have only ran up to 6S on these esc's.... But I can try 8S through one this weekend..Nothing like keeping you lipos warm and your prop wet!!Comment
Great!!!ReddyWatts fleet photo
Kind of curious on how tough the new 8c controlers are.......
Hello Ken nice to see you here , nice pics of the ESC's also......Necessity is the mother of invention.............
Youtube Video's http://www.youtube.com/user/Titanis2000Comment
I've been running a couple of the 8s Bec versions for a few months now. They are only running on 4s with an Ammo 2300 & the SV 27 motor So the Amp draw isn't high either.
The one with the Ammo is fine. The one with the SV27 motor ( in a 32" cat with a 445 prop) was working great until the other week.
As I plugged the batteries in the spark seemed a little bigger than usual and the ESC would not arm. No noises or beeps whatsoever. The BEC was still working because I still had power to the receiver & rudder servo. I tried unplugging & plugging a few times but she no go. I changed the receiver but still no luck.
If anyone can advise on what the problem might be and if it's fixable it would be appreciated.
Although this is outside the realm of this thread I still have to ask... Is there a simple way to reduce that splash across the plugs as you connect the batteries to the ESC?
Cheers.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
