Rudder mounted
Rudder is on the back of the boat now. Fits well, kicks up and looks like it will work. Not sure on the urethane casting resin, seems a bit brittle. I think the stuff I am using is only 3000 psi. You can get better resins, or I could just use epoxy. Harder to do, takes longer but for the few I need to make, it would work.
Getting close to running. With a 3s-1800 battery, I am looking at a running weight of 1 lb, 13 oz and it is one solid boat with the urethane foam and kevlar reinforcement.
Brian
Brian
