counter Rotating prop set up
  • showstoppercat
    • May 2007
    • 95
    With counter rotating props is it best to turn inwards or outwards?????????
  • Diegoboy
    • Mar 2007
    • 7244
    I have been told Inward for speed, Outward for stability.
    • G Doggett
      • 446
      For cats I have been told the same.
      However, I have tried both directions on my twin Jolly and can't really tell any difference.
      Maybe it depends on the hull.
      Graham.
      • showstoppercat
        • May 2007
        • 95
        thank you thank you
        • Jeff Wohlt
          • Jan 2008
          • 2716
          The real boats have the right side (driver side) turning LR (like our single drives) and the left side turning RR.
          The only way I can remeber it.
          www.rcraceboat.com
          [email protected]
          • Avanti
            • Nov 2007
            • 1280
            I recently got word that the timing would be messed up (and could cause issues) if you ran a brushless motor in reverse (ie. counter rotation). Does anyone have definitive information on this topic?
            back on topic; typically inward on a mono and outward on a cat
            • ReddyWatts
              • 1711
              That is true on a brushed motor, but not on a brushless.
              ReddyWatts fleet photo
              • Eodman
                • Sep 2007
                • 1253
                The way it was explained to me seemed to make sense!
                If you set the motors up to spin inward .. it would lift the bow ......
                If you spin them outward .. it would raise the transom or in effect lower the bow .....
                Inward and you fly the boat dryer -- outward wetter(slower?)
                Now I have no idea if that is true. As I get my twin drive jolly sorted out and can better understand what it does on the water maybe I can figure this out !!!!!
                We did it with a Bang!
                Cats Are Where It's At!
