Alan's Baby Oil cooled SeaKing 180, 6S in his Red Mono
  • questtek
    • May 2009
    • 556
    After destroying several SeaKing 180s on a 6S set up for his red Mono, Alan devised a baby oil cooling set up in addition to conventional water cooling. He also used a BEC and it worked. First run the prop was a bit too small but with a larger prop, on the second run, it ran......smokeless!
    (He was not so lucky with his brand new yellow Mean Machine. He was so excited to run his new build he did not put in any flotation or tape the hatch. Ran incredible...till it flipped. Sank to the bottom in less than 30 seconds with a big BURP (LiPos?) where Davy Jones now watches over it. Hope to recover it soon.)
  • Monstermanhbf
    TheQuadGuy
    • Dec 2010
    • 9
    Now thats pretty cool!
    That boat moves man!! NICE
    Chris
    https://www.facebook.com/MonstermanHBF
    • teamchrome
      • Jun 2010
      • 68
      WOW!!! Monsterman is here!!!
      Hey Chris, its billithed from HBF..
      To bad aboit the Meanmachine I hope to have mine soon.
      I orderd from Areomarine going on three weeks now.
      I still have no answers of when it left or when I get it
      Has anyone delt with them latley??
      • 57burb
        • 17
        Mineral oil is the same thing as baby oil, but without the smell.
        • FE Wannabe
          • Jul 2007
          • 626
          Hey Joe,
          Glad to see someone used your idea of immersing the ESC in oil and it worked well.
          Was the baby oil cooled by the water lines as well, or just the ESC?
          I could see using two water intake lines, one for cooling the ESC and motor and one for cooling the baby oil using some kind of cooling coil.
          How much weight do you guess was added with the addition of the container and baby oil? You might be able to get away with using less baby oil in a smaller container, if you can cool it. Even better if you could circulate the oil in the container.
          Just a thought.
          Another plus with this setup is you don't have to worry about getting the ESC wet since it is covered in oil. This looks like a good thing to try with the cheap chinese multi-layered aircraft ESCs that are tough to cool.
          Let me know if you guys plan on running there again anytime soon....
          Have a Happy New year....
          Brad
          SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
          • Jeff Wohlt
            • Jan 2008
            • 2716
            So what were the temps like on the ESC when you opened it up?
            www.rcraceboat.com
            [email protected]
            • drwayne
              • May 2008
              • 2981
              Baby oil, whale oil, seal oil.
              You guys in the US get all the good stuff.
              • Fluid
                Fast and Furious
                • 8012
                I was particularly partial to baby seal oil when I lived in Alaska....talk about soft skin!
                • Mel279
                  • Dec 2008
                  • 857
                  Im curious, how do u circulate the baby oil on cooling the esc?
                  • LiPo Power
                    DJI Drone Advanced Pilot
                    • May 2009
                    • 3186
                    Yeah, any details of how was the system done, pictures?
                    Great idea....
                    Canada
                    • questtek
                      • May 2009
                      • 556
                      His set up was very basic. Allen half-filled the contaner with baby oil. It does NOT circulate thru the ESC only on the exterior. The silicon tubes coming in are for cnventional water cooling as well as the battery and motor wires.
                      • drwayne
                        • May 2008
                        • 2981
                        Toasted a couple T180s before I added ext caps... now zero failure on 6S ( with bec ! ) DF33 CC1520
                        Alan's test in context with cap mod suggests conformal cap cooling may be the answer on standard T180.
                        W
                        • Jeff Wohlt
                          • Jan 2008
                          • 2716
                          Can you share the caps you used and link?
                          www.rcraceboat.com
                          [email protected]
                          • drwayne
                            • May 2008
                            • 2981
                            Jeff.
                            Extra buffer of 900-1200uf fits the required spec @6s.
                            Higher can voltage than source = more tolerance to heating.
                            Contra to ^V is 30% larger can.
                            regs
                            W
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              Thank you....2200 x50v. I like that setup, I guess you could have soldered them direct to the input lines. Was there a reason for the extra wire?
                              www.rcraceboat.com
                              [email protected]
