OK Guys, I picked up an old boogie board at a garage sale last year and decided to make a retrieve boat out of it.
I didn't take any actual build pics but as you can see from the finished state it is pretty simple.
The pics show the disaster that happened when at full speed, the retrieve net flew up and got in the prop. Back to the drawing board on that. I will have to put a limiting cable or spring on the retrieve net from to prevent that from happening again.
I put in a big 50mm outrunner swinging a 14 x7 three blade. Using a single 4350mah 5S pack. She runs around 25mph I'd say. Speed not that important.
I JB welded a LARGE piece of aluminum sheet to a rudder and now she turns on a dime. Good for retrieving. Also had to add a large single trim tab to keep the nose down.
I found that the bottom at the back of the cutout has to be carved out so it actually comes up on plane. Otherwise it just pushed water!
I'll try to get some detail pics later if anyone is interested?
