ok I have two 6s 5000 mah packs and i want to run 6s2p
I was told by castle tech today that I cant just seperate the dbl bat leads on a hydra 240 and seperate them so I end up with two posatives and two negatives then plug eack 6s into its own set of wire leads
bottom line is you cant seperate the dble leads on a esc....... so says castle?
is this true?
is this true?
