Lipo v. nimh
  • OJ racer
    • Dec 2007
    • 170
    Lipo v. nimh
    I'm building a new FE DF22, with an x-power 100a and Feigao 540L. I was planning on using lipos, but I can see you can get just as good output from nimhs, and lipos are really expensive if you still need the chargers. The point is: what are the advantages of lipo?
  • Bill-SOCAL
    • Nov 2007
    • 1404
    Not sure you mean by "just as good output", but here are the advantages of lipo:
    1) lighter weight for a given capacity.
    2) far better discharge rate - you can pull more amps with less heat build up
    2A) Maintains voltage better under load - flatter discharge curve
    3) Generally much longer service life when charged/maintained correctly.
    Disadvantages
    1) Cost more
    2) Requires special charger (cannot use NiCad/NiMH charger)
    I buy my lipos and chargers from Pat at RC Lipos
    Last edited by Bill-SOCAL; 03-20-2008, 07:01 PM. Reason: Added comments from below
    Don't get me started
    • motoxbob11
      • May 2007
      • 190
      Bill is right but don't forget the discharge curve is much flatter with Lipo. The power stays consistent through the run and doesn't get soft after a couple minutes like Nimh does.
      • GregS
        • 82
        Also, lipos maintain there voltage better when under load.
        Greg
        • ReddyWatts
          • 1711
          NiMH's still work fine for sport running, just keep the IB/EP packs under 100 amps and make sure they have heavy connecting bars. Brands that use the thin connecting tabs, keep under 50 amps.
          ReddyWatts fleet photo
          • Mich. Maniac
            Banned
            • 1384
            Disadvantages
            1) Cost more
            What took you soo long to get here Bill? You give GREAT advise and with facts to back it up. These are the posts I love to read. thanks
            • Bill-SOCAL
              • Nov 2007
              • 1404
              Thanks for the kind words. I try to back up my BS whenever possible!!
