SV 27 vs BJ 26 (motor and esc)
  • Doug Smock
    Moderator
    • 5272
    Realiability, which one gives the best service when used in reasonable setups??
    I'd really like to hear from those who have used both.
    Thanks,
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  • RCprince
    • Jul 2007
    • 1637
    Personally I like the BJ set up with lipo's..I've heard of problems with nimhs..and I've had problems with nimhs, but with lipo's.. it's sweet...plus the BJ set up hands up to a 5s max so a 4s would be perfect...plus the cogging is not as pronounced on the BJ motor...one discrepancy is the BJ motor rpm..some say 1500kv some say 1606kv, another thing is the BJ cooling set-up to me is much more efficient.
    • SJFE
      • 4735
      Doug IMHO from a performance standpoint the AquaCraft system is the way to go. Neil is correct in regards to the cooing being better on the ProBoat system. This as we both know is over come with a good aluminum jacket and some home made copper cooling plates. The SV system seemed to produce more torque..again IMO. The SV esc is also much smaller and lighter than the PB unit. If I where going to run a spec 4s class the SV system would be my choice.
      Tom
      • Darin Jordan
        • 8335
        Is the BJ motor a slotted or slotless design???
        Darin E. Jordan - Renton, WA
        • Doug Smock
          Moderator
          • 5272
          I haven't been able to find any info on them Darin. Can you shed any light on it Steven?
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • SJFE
            • 4735
            What would be the difference?
            • Jeepers
              • May 2007
              • 1973
              Hey Doug we have a class of hydros running both systems it seems that the AQ system seems more reliable and faster.
              The two boats running the BJ sytems the esc keeps cutting cutting out in them.
              • RCprince
                • Jul 2007
                • 1637
                The BJ motor can is the same as the SV slotted 18 But the BJ rotor magnets are not exposed like the SV...The BJ Rotor has a Black coating over the magnets
                • RCprince
                  • Jul 2007
                  • 1637
                  I opened a BJ and SV motor The BJ is on the left and the SV on the right, Both have 6 magnet strips and 18 metal slots in their cans
                  • Doug Smock
                    Moderator
                    • 5272
                    You are a Prince RC but you didn't have to do that! Thank you sir.
                    Jeepers, you know where I'm going here. What size prop are you guys running on the hydros.
                    Thanks guys,
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • calcagno45
                      • Mar 2008
                      • 1006
                      Class act right there!! Mucho props to you RCprince!! good pics!
                      • Doug Smock
                        Moderator
                        • 5272
                        No doubt!!!
                        How far are you from Cordele Ga. Mr. Prince??
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • Darin Jordan
                          • 8335
                          Is the BJ motor tough to turn over by hand like the SV motor??
                          • RCprince
                            • Jul 2007
                            • 1637
                            The BJ motor has a less pronouced cogging than the SV motor way less
                            • RCprince
                              • Jul 2007
                              • 1637
                              D.smock I'm about 6 hours south of Atlanta a city adjacent to Orlando, fl
