Results 1 to 4 of 4
Thread: MG offset rudder and breakaway conversion..
    Default MG offset rudder and breakaway conversion..
    Have bought from Kintec racing the Mystic breakaway and offset rudder conversion for my new Miss Geico 29,and I cannot work it out how to fit,please can anyone help ?
    Thanks guys..
    Iam who Iam, except this and we will get along fine..
    Sounds like you should of got the geico offset mount. The mystic bracket will cover up the hole for your servo arm. Therefore you'll need to move the servo. If you did do that you would likely need to cut your port side strut bracket down shorter as well. I'd contact kintec and see if you can ship it back and swap it out for the geico. The blackjack mount would work but still would need to cut the port side strut bracket. They're all slightly different and labeled blackjack/mystic/geico for a reason.
    Ya have I the Miss Geico mount,just need to know how to fit,thanks for your prompt reply...
    Sorted,ta
