Results 1 to 6 of 6
Thread: nylon breakaway screw for rudder - where to buy
    Default nylon breakaway screw for rudder - where to buy
    I've seen several MG29's with a nylon breakaway screw in the lower rudder bolt hole. I would like to change mine to that setup. I know it is a simple question, but where do you buy that screw. The only 3mm nylon screws I found were too short.
    Thanks,
    Bob
    I get mine from ebay. Any size you need:
    http://www.ebay.com/sch/i.html?_trks...screw&_sacat=0
    http://www.kintecracing.com/Nuts___Bolts.html
    near the bottom of page. Probably not cost effective unless you need some more stuff.
    Thanks!
    Bob
    I use a 4mm one.I found the 3mm allows the rudder to move a bit.I'm probably a little late here,Sorry
    No problem, thanks for the input. I saw on e-bay (from post above) you can get a packet of 100 relatively cheap, so I will have a lifetime's supply
