View Full Version : AquaCraft SuperVee 27 Q & A
Pages : [1] 2
  1. my 27...
  2. Here you go
  3. Grim's setup
  4. My Sv Clips.
  5. Merge the classes?
  6. 7 cell packs?
  7. lipo on sv
  8. upgrade motor for sv27
  9. Battery Supplies for SV27 page
  10. SV27 Props
  11. SV27 Nitro
  12. Hardware Config
  13. Death of a hull
  14. Lipo DPR Tests
  15. turn fins
  16. My SV's new look
  17. batts
  18. Grim retrieval device
  19. SuperVee Hull
  20. Hareware Setups
  21. Removing the ClearCoat??
  22. Motor for sv27??
  23. boating safely
  24. hull construction
  25. Octura Flex Shaft
  26. Water cooling leaks !
  27. Low Voltage Cut-off
  28. Water Cooling Through-hull fitting??
  29. ran my sv for the first time
  30. Get a better Radio - - SPEKTRUM
  31. urgent!
  32. sv rudder pin
  33. show us your sv27
  34. sv27 mods
  35. shifting gears
  36. SV StockBoat series
  37. LiPos cause motor to stutter except at full speed
  38. supervee esc Q
  39. motor upgrade.
  40. Got Mine Last Night
  41. SV motor and esc
  42. SV Nitro
  43. Striped set screw in the flex coupler
  44. New SV can't pass bathtub test
  45. Super Vee 27 Problem
  46. charger recommendations
  47. Gap size brtween flex coupler and stuffing tube
  48. i might get the SV running sooner than i thought
  49. Advice on drive line
  50. SV27 esc question
  51. Setup tips from an experienced club....
  52. Switching to LiPo's
  53. Fiegao motor upgrade
  54. Best Batt Charger?
  55. SV27 Water Cooling Problem
  56. polarity of radio charging jack
  57. Would you recommend a SV 27?
  58. major hull repair
  59. pics of radio box
  60. Back in the SV game.
  61. prolly going to have to sellit....
  62. My sv hull cracked-just paint or in fiberglass
  63. Stripped bolt holes in motor
  64. What is the best all around prop for the SV27????
  65. SV27 Motor on "OTHER" ESC??
  66. Stopping Water Leaks on the SV27
  67. Bodywork on sv27 hull?
  68. Arming beeps?
  69. Speed control voltage cutoff
  70. Sv27 Whaaaa Whaaaaaaa & Whaaaaaaaaaa
  71. motor coupler stuck
  72. Melting Batt connectors
  73. rebuild after 2 to 3 years of abuse
  74. SV hardware
  75. Video of some sv27 this past Sunday
  76. Supervee 27 Quality Issues
  77. Rudder Placement
  78. SV run Problem
  79. SV brushless balance point
  80. Fla SV's on a typical Sunday
  81. Won't get on plane
  82. sv 27 motor
  83. Carbon fiber props for SV27 Brushless
  84. Ammo motor
  85. prop question
  86. SV Strut
  87. new motor
  88. Supervee Problem
  89. heat issue
  90. Props 3 blade vs 2 blade
  91. prop suggestions
  92. Time to put up SV owners
  93. RTR Package for our club
  94. new motor
  95. Super Vee Flex cable
  96. stock prop; comment
  97. For newbies, Motor Care 101
  98. ammo motor
  99. So Cal
  100. Who is running an aftermarket motor and esc
  101. My SV in action
  102. brushless cooling system?
  103. Things I've learned about my SV27
  104. new SuperVee Owner need little advice
  105. SV27 setup and speed
  106. supervee race in georgia
  107. Supervee charger
  108. 14 cells = Radio Problems
  109. SV 27 ESC problem
  110. Futaba 3PM FM
  111. TX Batteries
  112. 4S2P Lipo
  113. Turbo Transmission?
  114. cavitation problems
  115. Just thought I would share
  116. Lipo Set up
  117. Can this Happen
  118. Not Looking Good
  119. AquaCraft ESC
  120. SV Back on the road.
  121. Esc or Battery problems? What do you think?
  122. Thrust bearing?
  123. sv27 GPS Speeds!!
  124. Lipos ROCK
  125. Cracks
  126. Questions from a newbie
  127. SV27 paint colors
  128. ESC Stock Cooling Issue/Fix
  129. X-Power Brushless ESC
  130. newbie
  131. prop nut?
  132. SV Rudder
  133. Rescue Boat
  134. First Sv
  135. check this vid
  136. feigao vs ammo
  137. Pulso 70amp ESC with 12L
  138. ESC(?) Issues - It won't arm.
  139. Trying this in the morning
  140. Reciever pack with SV27 motor and SC?
  141. Has anyone tried staggering their battery placement?
  142. motor mount mod
  143. How Far Deep Vee Has Come
  144. SV27 Newbie Questions
  145. Steering question(a villain sv27 pseudo hybrid
  146. Stupid voltage cutoff
  147. flex cables and shafts Quick Question.
  148. hydra 120a
  149. lipos for sv27?
  150. T-Cat 31
  151. More supervee questions
  152. Best Prop for Speed
  153. Noob looking for boat
  154. Tenergy Propel 7.2V 4500mAh Nimh (45A Drain Rate)
  155. Grim Racer 440/3 versus others
  156. Supervee 27 Powerhouse setup
  157. Oil System
  158. Prop suggestion with ammo.
  159. Fixing the BJ26 Handling Issues
  160. Hydra 120 and 6s lipo?
  161. Traxxas VXL Brushless in a SV?
  162. Supervee for sale!!!!!!!!!
  163. Swamping a motor
  164. Roll over kit
  165. Speed with ammo & props again...
  166. The SV27 satisfies
  167. wont run rt
  168. Melting battery lead solder connections
  169. Adjustment advise?
  170. www.kintecracing.com
  171. What epoxy for my SV27?
  172. Prop question..
  173. Waterproofing sv27
  174. SV strut bushing
  175. scuffing
  176. Nimh vs Lipo?
  177. hatch
  178. Spectrum Radio
  179. Problem with SV ESC and 3pm 2.4
  180. Water cooling hole
  181. Supervee27 planing problems.
  182. Barricuda125 ESC HELP!!!!!
  183. Aquacraft SV speedo not arming
  184. upgraded sv27
  185. thrust bearing
  186. Lipo cut off
  187. How many amps does the SV 27 pull?
  188. So electric boats CAN have runaways!
  189. motor choice big $ or little $ ?
  190. Supervee brushless vs Supervee nitro
  191. Info on hop-ups for SV27
  192. supervee 27 battery issue
  193. bec battry.
  194. Race Legal SV
  195. Warm temps today.
  196. what battery pack is the best fit
  197. European SuperVee 27 Order
  198. only one beep
  199. Adjusting the strut angle.
  200. Adjusting the strut angle.
  201. fail safe
  202. SV27 submarine??
  203. quick noobie lipo question
  204. Radio glitching
  205. Newbie,Needs help with leak!
  206. 8XL with stock ESC
  207. Safety measures for working with props
  208. still slow sv27
  209. SV27 Motor
  210. Ultra modified SV 27 pics ...
  211. Hello, new to this
  212. LIPO ,s ???
  213. Trade speed for run time?
  214. what is the cell limit on sv27 esc
  215. flipped
  216. Want to run 7 cell batteries
  217. 8xl xpower 100 prop?
  218. 7 cell SV27 with 6 cell batteries
  219. Flipped Boat
  220. Prather prop
  221. 3 small questions.
  222. Novak 550 brushless,but which ESC to use? Need to know about Novaks 7.5 PRO amp draw
  223. Hatch mod
  224. Building a tool bag am I missing anything
  225. trim tabs for speed
  226. Prop Finishing Advice
  227. Esc programming module
  228. SV Prop
  229. ESC Connections
  230. Removing the strut
  231. Paint for SV27?
  232. Thrust bearing install
  233. Stuffing tube teflon insert-how long?
  234. Elite Lipos
  235. would a k51 work?
  236. supervee 27
  237. Picture of exaust water spill ?
  238. Best prop for sv27???
  239. SV27 Battery Help
  240. Puffed Maxamp lipo - what to get now?
  241. SV Strut Length
  242. Need to break 40 MPH...HELP ME
  243. sv27 battery ?
  244. connecting a ubec
  245. So for 49.4
  246. I'm Moving up 50.2
  247. Lipos for supervee27
  248. Naysayers Bow to the Master
  249. this is ugly
  250. 52.5 mph video
